4 wheel drive vacuum valve - Ford Truck Enthusiasts Forums
Old 11-10-2005, 11:47 AM
dao57 dao57 is offline
dao57 is starting off with a positive reputation.
Help ! My 97 f150 4x4 won't go into 4 wheel drive. The manual transfer case shifter is locking in the transfer case, but the vacuum valve on the differential shift lever isn't working. There is vacuum on one hose when 2 wheel drive is selected, but vacuum is on BOTH hoses when 4 wheel is selected thus preventing the lever from actually changing positions.Anyone know of a diagram or print on what operates the solenoids on the 2 vacuum valves ?
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 12:59 PM
Transfer case / Hubs / Diff / Vacuum confusion Enduroman 6.0L Power Stroke Diesel 17 12-06-2013 02:53 PM
Can't move transfer case lever-stuck in 4x4 daltonruff 1997 - 2003 F150 5 02-19-2012 12:22 AM
esof vacuum solenoid test flatheadshoals 1997-2006 Expedition & Navigator 12 09-20-2009 11:10 AM
ESOF vacuum pump problem. conger 1999 to 2016 Super Duty 16 10-20-2008 06:58 PM
Tags
2003, drive, f150, f350, vacume, vacuum, valve, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
