Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
'01 Escape Shifting Linkage
Old 11-09-2005, 08:24 PM
berwicktony's Avatar
berwicktony
berwicktony is offline
Question '01 Escape Shifting Linkage
Hi all. My wife has an '01 5-speed. THe Shifter has become pretty sloppy. With the lever in 1st, 3rd and 5th I feel like I can pull the shifter back towards me about two inches before the linkage pulls and I drop back into the neutral area. On the other hand, pulling down into 2nd, 4th, Rev. I feel like the thing is barely catching, (and sometimes a little grinding on engaging the clutch) . My question to all you guys in the know is : Is there any way of adjusting the cable in question, or is it just a case of it being worn and stretched and in need of replacement? Any advice or opinions would be welcome...thanks.
Old 11-10-2005, 07:44 AM
inspectorguy's Avatar
inspectorguy
inspectorguy is offline
No cable, hydraulic system, self-adjusting. Sounds like you just need to have the shifter linkage bushings replaced. Made a world of difference on mine. With an 01, you might even condsider replacing master and slave clutch cylinders just to be on the safe side. Hydraulic systems are subject to interior rusting as the hyraulic fluid [brake fluid] can hold moisture.
Old 11-15-2005, 11:36 AM
berwicktony
Thanks for your observations, inspectorguy- the rig is actually going into the dealership tomorrow. I hope they square it away so I can let Wifey have it back. It's an OK rig for HER (bright yellow) but I'm looking forward to taking my Gr. Cherokee back.
Old 03-10-2006, 08:31 PM
cinbearcat's Avatar
cinbearcat
cinbearcat is offline
2001 Manual Tran. Shifting Problem
My 01 has the exactly the same problem as you described. What was the solution?
thanks
Old 03-11-2006, 05:39 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
npavao86
1999 to 2016 Super Duty
11-20-2016 08:23 PM
Scfsouth
18
03-20-2016 10:06 PM
Bassindude
05-12-2015 06:49 AM
eddie76
12-04-2014 11:14 PM
MMSCHWE
12-03-2010 06:32 PM
Quick Reply: '01 Escape Shifting Linkage
