76 ford
76 ford
Hello Guys,
I am looking at a 1976 ford f250 4x4 with the 4 speed, limited slip axles, and a 390 2 barrel carb, with headers(from the factory ), any way, I was needing to know what hp and torque the motor put out, and what was the lowest gears available from the factory(I hope 4.10). The truck has not run in 2 years, so it will be a fixeruper for sure. Thanks in advance for the info, Mason
76 ford
Here is some info on axles for the 1976 Model year
AXLE Model & Year
Front Dana 44 1976 F-250 3/4 Ton pick-Up
(Part-Time Transfer Case)
Axle Type RATIO & (Tooth Combination) Bill of Material
Standard 3.54 (46:13) 603783-7,-8
Standard 4.09 (45:11) 603783-1,-2, -5
Trac-Loc 4.09 (45:11) 603783-3,-4
Det.NoSpin 4.09 (45:11) 603783-6
Standard 4:55 (50:11) 603783-9
(Full-Time Transfer Case)
Standard 3.54 (46:13) 603784-2
Standard 4.09 (45:11) 603784-1
Trac-Loc 4.09 (45:11) 603784-3
AXLE Model & Year
Rear Dana 60 F-250 1976 (3/4 Ton pick-Up)
w/ Full Float axle design
Standard 3.54 (46:13) 603717-1
Standard 4.10 (41:10) 603717-9,-11
Trac-Loc 4.10 (41:10) 603717-10,-12
Det.NoSpin 4.10 (41:10) 603717-17
Trac-Loc 4:56 (41) 603717-16
AXLE Model & Year
AXLE Model & Year
76 ford
Thanks for the axle info. Yes I am positive it is a 390, and the lady that owns it said that it came in the truck new. I am sure you are right. What I wonder is was there some sort of special package in a 4x4 were you could get the 390, the other oddity here is that it also came with headers new. I did see the ticket for the truck when they bought it, and it says that it came with the 390, with headers, and the 4 speed, with part time divorced transfer, in 2/76. It made no mention of the axle ratio, but did say it was trac lock, so I guess that means 4.10 . Thanks for the info, Mason
76 ford
Well the deal fell through . It looks like I will just have to repair the chevy I have, no ford for now. Thanks for the info guys, it has been very helpful. Just so you know the truck is about wore out and they wanted alot more than I could aford and still fix it. Thanks agian for the info, Mason
