You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am looking at a 1976 ford f250 4x4 with the 4 speed, limited slip axles, and a 390 2 barrel carb, with headers(from the factory ), any way, I was needing to know what hp and torque the motor put out, and what was the lowest gears available from the factory(I hope 4.10). The truck has not run in 2 years, so it will be a fixeruper for sure. Thanks in advance for the info, Mason
__________________
79 chevy k30 altered alot 76 mercury grand marquis 400m v8, c6 auto, 2 door hardtop
Here is some info on axles for the 1976 Model year
AXLE Model & Year
Front Dana 44 1976 F-250 3/4 Ton pick-Up
(Part-Time Transfer Case)
Axle Type RATIO & (Tooth Combination) Bill of Material
Standard 3.54 (46:13) 603783-7,-8
Standard 4.09 (45:11) 603783-1,-2, -5
Trac-Loc 4.09 (45:11) 603783-3,-4
Det.NoSpin 4.09 (45:11) 603783-6
Standard 4:55 (50:11) 603783-9
(Full-Time Transfer Case)
Standard 3.54 (46:13) 603784-2
Standard 4.09 (45:11) 603784-1
Trac-Loc 4.09 (45:11) 603784-3
AXLE Model & Year
Rear Dana 60 F-250 1976 (3/4 Ton pick-Up)
w/ Full Float axle design
Standard 3.54 (46:13) 603717-1
Standard 4.10 (41:10) 603717-9,-11
Trac-Loc 4.10 (41:10) 603717-10,-12
Det.NoSpin 4.10 (41:10) 603717-17
Trac-Loc 4:56 (41) 603717-16
__________________
John Workman
89 F350 Crew Cab Long Bed
Previous projects - 76 F250 Crew Cab Short Bed
4x4 460 C6 Dana 60 F/R.
77 Bronco 302 3spd Jsworkman@MSN.com
Thanks for the axle info. Yes I am positive it is a 390, and the lady that owns it said that it came in the truck new. I am sure you are right. What I wonder is was there some sort of special package in a 4x4 were you could get the 390, the other oddity here is that it also came with headers new. I did see the ticket for the truck when they bought it, and it says that it came with the 390, with headers, and the 4 speed, with part time divorced transfer, in 2/76. It made no mention of the axle ratio, but did say it was trac lock, so I guess that means 4.10 . Thanks for the info, Mason
__________________
Well the deal fell through . It looks like I will just have to repair the chevy I have, no ford for now. Thanks for the info guys, it has been very helpful. Just so you know the truck is about wore out and they wanted alot more than I could aford and still fix it. Thanks agian for the info, Mason
__________________
If the 390 DIDN"T come from the factory---did the dealer install the 390 After it arrived at the dealership , in the f250 4x4 , but before the customer took possession of the truck??????fd :-X11
__________________
Eat More Possum----i'll add more later
