Transfer Case Leak
Transfer Case Leak
Hi there. I have a 1979 f150 4x4 with a 351m. The transfer case is leaking from the front output shaft. I am getting ready to change the seal. Do I have to pull the transfer case or can I pull the front driveline and pop out the seal then replace? Does the yoke just pull out? Any help would be appreciated. Thanks,Troy
The front output seal can be replaced with out pulling the transfer case. If truck is equipped with skid plate, remove skid plate to make access of seal more accessable.
The u-bolts must be removed to remove driveshaft from transfer case.
The yoke on transfer case must be removed. The seal must be removed with a seal puller. Keep old seal to match up with new oil seal. Verify that the yoke does not have any grooves on the portion where the oil seal and yoke make contact. Be carefull not to damage new oil seal on installation.
You can do it with the case in. Remove the big nut and pull the yoke off. Pull the seal and pop in a new one.
You can also remove the 4 nuts that hold the aluminum housing on and take the housing off. That'll make it a lot easier. Also, check the surface of the yoke for grooving, and replace it if it's damaged.
Hope this helps.
Kevin K.
Hope this helps.
Kevin K.
welp, it shouldn't be but 4 bolts to take the front drive line out. Drop it from the Tcase, and look inside the yoke. If it has a big nut in there, then I would see why it couldn't be dealt with like newer Tcases. Remove the nut, use a 2 jaw puller if need be and remove the yoke. Pry out the old seal, clean up the seal bore in the Tcase, make sure no dirt gets/got in and tap the new seal in.
Now, why is the seal leaking? Is it worn/craked? Or does it have a groove worn in wear the seal seats? If there is a groove, you might need to put a repair sleeve on the yoke, else a new seal will leak too. Repair sleeves should be available at the same place as the seal (just about any quicky Auto-store)
EDIT: This is why you shouldn't answer a PM while answering another question, then back paging and post
Check out picture of assembly of the transfer case on my gallery.
I've used a fine grit emery cloth and sanded the groves down a bit. Sand the groves smooth and in the same rotation of the grooves. If the grooves are deep put a replacement sleeve or a new yoke.
Once the yoke is off, take the 4 bolts off to remove the bearing retainer off the Transfer case. The seal then can be removed.
When installing the new seal, put some light grease on seal portion where it contacts the yoke, this will ensure that seal does not run dry.
Now would be a good time to inspect the front u-joints and replace if necessary.
Check vent holes for transfer case and make sure that it not plugged or restricted, clean if necessary.
CountryBumkin
08-22-2014 12:42 PM
John Thomas II
09-21-2013 08:40 AM
79f100six
09-10-2007 02:58 PM
jd_boggs
07-13-2006 07:57 AM
