what oil to use in FE 360 - Ford Truck Enthusiasts Forums
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Old 11-09-2005, 09:19 AM
Cenzo777 Cenzo777 is offline
Cenzo777 is starting off with a positive reputation.
I was browsing through the threads a few months ago and i remember something about using diesel oil in the FE engines? I am posting this topic because i can't find where the thread is. Any suggestions as to what weight to use ? 15w40?
Any help would be great. even if you can find that old thread so i don't eat up space on the forum!
1975 ford f350 dually "The 75"
Old 11-09-2005, 10:21 AM
bob arrington bob arrington is offline
bob arrington is new and has a neutral reputation at this point.
15X40 is good , you might check the FE forum as 360s are FE engines , and I think using up space helping each other out is a good thing and one of the reasons this site is here,bob
Old 11-09-2005, 10:34 AM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
I would stay away from the Diesel oil... Run what oil is appropriate for your climate, nothing special needed. I run 10-30 in my older vehicles (pre-90) and the recommended mfg weight in the newer ones (generally 5-30).
--Mike
Old 11-09-2005, 10:43 AM
74hiboyboy 74hiboyboy is offline
74hiboyboy is starting off with a positive reputation.
Yep, 10-30 is good 15-40 is a little thick in the cold.
Old 11-09-2005, 04:24 PM
77300i6's Avatar
77300i6 77300i6 is offline
77300i6 is starting off with a positive reputation.
I run Shell-Rotella 15w40 in my 300L6. The diesel oil has more anti-wear additives in it.
Old 11-09-2005, 08:05 PM
4starcstms 4starcstms is offline
4starcstms is starting off with a positive reputation.
I run Royal purple synthetic 10w30 usually, just dont break a engine in on synthetic ..
Old 11-09-2005, 08:59 PM
wintremute's Avatar
wintremute wintremute is offline
wintremute is starting off with a positive reputation.
I run 10w40 summer and 10w30 winter
Old 11-10-2005, 10:18 AM
1975Ford's Avatar
1975Ford 1975Ford is offline
1975Ford is gaining momentum as a positive member of FTE.1975Ford is gaining momentum as a positive member of FTE.
I run 5w30 in winter and 10w40 in summer.
Old 11-14-2005, 06:06 AM
tomcasino's Avatar
tomcasino tomcasino is offline
tomcasino is starting off with a positive reputation.
I run straight 30 Valvoline in my 390 in the summer and 10w30 in winter.
Old 11-17-2005, 03:43 PM
green 1969 f100 green 1969 f100 is offline
green 1969 f100 is starting off with a positive reputation.
10w30. My preference is the Connoco/Philips family consisting of Motorcraft,Kendall,Phillips,etc.
Old 11-17-2005, 04:28 PM
oppy's Avatar
oppy oppy is offline
oppy is starting off with a positive reputation.
Quote:
Huh??
Actually, diesel-grade oil would be a great choice for you, with a much better additive package, especially for an older vehicle. It is available in 10W-30. I use Mystic JT-8 Super Heavy Duty, but there are others that are good as well - Rotella T, Delo 400 to name a couple.
Old 11-22-2005, 10:59 AM
strider9 strider9 is offline
strider9 is starting off with a positive reputation.
what oil to use in FE360
I vote for the 15-40W family of diesel oils. Delo 400 or Rotella are excellent choices. You might pay a penalty in milage(theoretically) with the thicker base weight 15, but the diesel family offers a superior additive package.
Old 11-22-2005, 11:11 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
I use the Mystik 10w30 mentioned above in my high performance 390. It does work good. Had the heads and intake off a couple months ago, and got to look at the cam. It broke in correctly.
I used the same oil in the old 360 I took out. Everything was nice and clean when I took it apart.
Old 02-16-2016, 02:06 PM
OLDBLUEF250's Avatar
OLDBLUEF250 OLDBLUEF250 is offline
OLDBLUEF250 is starting off with a positive reputation.
what should i use in my fe 360 with a slight knock? Its a tired engine
Old 02-18-2016, 01:16 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Quote:
If you live in a warmer climate with mild winters I'd be inclined to run a 15w40 Rotella or Chevron Delo diesel oil. You should be able to find either at Walmart or any decent auto parts store.
FE Big Block: FREQUENTLY ASKED QUESTIONS Ratsmoker FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 09-09-2016 01:18 PM
360 FE 4x4 Headers Shanekacz 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-09-2016 11:52 AM
WHAT WEIGHT OIL ARE YOU RUNNING IN THE FE's ford390gashog FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 105 12-04-2015 03:01 PM
Pre 65 352 FE block or newer? Ken Kitson FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 05-11-2015 01:38 PM
adapters for compression tester rebocardo Garage & Workshop 8 02-09-2004 01:50 AM
Tags
1969, 360, 390, 50, diesel, fe, fe360, ford, oil, run, summer, texas, type, weight, wht, wieght
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
