11-08-2005, 11:58 PM
Yes, you need a flywheel with the 28oz imbalance. 300's are internally balanced. The good news is that it should be rather easy to find one. 289's, early 302's, early 351W's, 351M, 400.
Should you change to a balanced flywheel? Yes. You'll beat your main bearings up pretty quickly.
The stock harmonic balancer should have been fine.
__________________
Best regards,
Paul Menten
