y block dipsticks - Ford Truck Enthusiasts Forums
y block dipsticks
Old 11-08-2005, 08:33 PM
61ford 61ford is offline
61ford is starting off with a positive reputation.
y block dipsticks
can anyone explain this one?i bought a yblock believe a 292 while back and it has 2 dipsticks both going into the block,one right behind the generator and one underneath the pass side exhaust manifold.i cant figure out why it has 2?
Old 11-08-2005, 09:12 PM
wild.bunch's Avatar
wild.bunch wild.bunch is offline
wild.bunch is gaining momentum as a positive member of FTE.wild.bunch is gaining momentum as a positive member of FTE.
The one in the front is for the front sump oil pans used in cars. The one in the middle on the passenger side is for trucks that have the mid engine sump. The engine is fitted with one or the other to match the pan or, I guess, with both in your case!
Old 11-09-2005, 05:33 PM
thanks wildbunch after you said that i went and checked and the front one is a dummy. are all the y blocks made like this?
Old 11-10-2005, 08:13 AM
wild.bunch's Avatar
Yes, I believe that they are.
Tags
292, block, dipstick, ford, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
