Front and rear sump
Fordeverpower is absolutely correct. However a front sump will fit on a 76 Highboy. The truck 352 I have in my truck accidently fell off the cherry picker and crushed the rear sump pan. Only fell about 4 feet but a full dress FE is heavy. Only thing I had was a front sump pan, I put that on until I could get a rear sump pan. The one on the 390 I took out of the truck was leaking and I had to have the flanges straightened before I could use it. Only thing is be careful when you're four wheeling, looks like if you stuff the suspension hard the oil pan will say good bye. I have a rear sump on it now.
if it's a half ton 72, i've seen the panhard bar hit a front sump pan... a buddy pulled a motor from a 2 wheel drive and just put it straight into the 4x and didnt wanna change the pan and pickup.. hit a water bar pretty hard out wheelin' and the rest is a oily spot in the history books... LOL
Curtis360
05-19-2002 09:48 AM
