rattle
what kind of rattle from the inside of the engine or out side of the engine. if you give it gas does the or a knock get louder? check the heat shields and exhaust system for loose heat shields they can make a racket. The oil pressure can either be a bad sensor easy fix, or a loose or corroded wire on the sensor. or you have oil pump problems, sounds like a sensor problem though. if you suspect a oil pump then do a oil pressure test at the sending unit, (removed of course). If you don't have a stethiscop (Mechanics) then use a long rubber hose or garden hose to listen around the engine to try to isolate the noise. (be care ful not to get it stuck in moving pares like the belt or fan)
Lance
Lance
Dwayne1
Escape & Escape Hybrid
12-03-2013 11:27 PM
bigtexan99
09-02-2011 11:39 PM
laneyboy6933
06-09-2007 06:02 PM
