Which Transmission Do I Have? - Ford Truck Enthusiasts Forums
Old 11-07-2005, 10:10 AM
72SMITH 72SMITH is offline
72SMITH is starting off with a positive reputation.
I resently purchase a 96 F-150 with 300-6 and an auto transmission. I am trying to find out which transmission I have. The transmission code on the door is "E". Is there a list anywhere to say which transmission I have
Thanks
Rob
Old 11-07-2005, 10:31 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
im 99% no 100% sure that it is a e4od transmission
Old 11-07-2005, 11:27 AM
low92flareside low92flareside is offline
low92flareside is starting off with a positive reputation.
Yes, Trans code E for the E4OD trans
Transmission Spotter's Guide:
http://www.ford-trucks.com/article/i...ers_Guide.html
Old 11-07-2005, 12:21 PM
Thanks for the help
Old 11-07-2005, 12:28 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
ford sure a E4OD
Old 10-10-2007, 07:55 AM
torrrch76 torrrch76 is offline
torrrch76 is starting off with a positive reputation.
my transmission in E 350 ,1991 model is marked ...RF-E9TP-7A040-CB.IS TAHT AN E40D PLEASE.THANKS
Old 12-03-2008, 03:42 AM
foxyman foxyman is offline
foxyman is starting off with a positive reputation.
1991 e40d transmission
is the rf-e9tp-7a040-cb a e40d transmission
Old 12-03-2008, 03:50 AM
did you find out if that was the e40d transmission
Old 12-03-2008, 05:21 AM
E350 transmission(AUTO)
it is definitely an E40d transmission
Old 12-03-2008, 05:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1990/2002 Ford Light Truck Parts Catalog sez: E = E4OD or 4R100.
E9TP-7A040-CB is not the trans ID number. It's the ID number for the extension (tailshaft) housing.
E4OD & 4R100: The transmission ID tag is on the drivers side of the case, just behind the manual control lever.
The code may resemble this: F7SP-AA / The model number will resemble: PRA-AA.
Transmission cooler return line bvieages Escape & Escape Hybrid 3 05-31-2011 09:48 PM
4R70W Oil Cooler Lines; Which is in and which is out?? Trigger200 1997 - 2003 F150 5 06-07-2009 05:27 PM
1980 F150 Manual Transmissions rbeatty 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 05-03-2004 12:56 PM
transmission cooler return line orange78oval 1978 - 1996 Big Bronco 1 02-09-2004 02:20 PM
Which transmission do I have? John7894 1987 - 1996 F150 & Larger F-Series Trucks 10 07-14-2002 06:43 PM
Tags
1992, 350, 7a040, code, e40d, e4od, f150, ford, housing, identification, rfe9tp7a040, rfe9tp7a040cb, tailshaft, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
