460 vs 454 - Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
460 vs 454
Old 11-07-2005, 08:38 AM
jimford1 jimford1 is offline
jimford1 is starting off with a positive reputation.
460 vs 454
I know that this was probably done before but what the he!!. I was wondering overall which big-block has the most potential all around. I know the 454 has 4 bolt mains. My friends father runs a sick 460 in his tubbed 69 mustang. He does ok at drags. Is it just the setup of everything like suspension, tires. Driver also right? He has to be pushing at least 500 hp. I was surprised to see so many fords at the drags. Saddly surprised. The fastest car there was a cobra drag car. That thing ripped!! Dont know what it was running. I was getting looks from everyone because when the fords were up I was yelling and getting crazy. I guess the reason for my post is why dont people use 460's more in drag racing. Or do they? Why arent there more Old fords in nastolgia racing? Kurt Neighbor is my hero!!
Old 11-07-2005, 06:31 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
If you are just talking about racing, I would bet on the 454. A lot more development work has been done on Chevy Big Blocks, and a lot more parts are available.
Old 11-07-2005, 06:59 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
"Why don't people use 460's in racing?"
I would say simply is the cost. So fewer people use them that the parts cost more.
Old 11-07-2005, 07:45 PM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
500hp is nothing for the 460. I believe the 460 is more capable in terms of power, but there seems to be much more aftermarket for the GM.
Old 11-07-2005, 10:33 PM
Ry_Trapp0 Ry_Trapp0 is offline
Ry_Trapp0 is starting off with a positive reputation.
if you know what your doing you can build up a 460 with a combination of 454 parts and the limited parts available for the 460. i think it was last year when petersons 4 wheel & off-road did a 460 build up this way.
Old 11-07-2005, 11:12 PM
Stick Chevy parts in a Ford engine?????
...I don't think so...
Old 11-07-2005, 11:21 PM
it should be illegal, but if you want some power/strength i guess it must be done. technically you could call them just aftermarket parts instead of chevy parts, lol.
Old 11-07-2005, 11:59 PM
Nawww...You should go check out the offroad forum. There are a couple guys over there with 460 that have absolutely no GM parts in them, pushing some serious numbers...the 460 itself is much more capable then the 454.
Old 11-08-2005, 01:22 AM
What about the 460 makes it much more capable than a 454? Just curious.
Old 11-08-2005, 07:42 AM
F250Wildman F250Wildman is offline
F250Wildman is starting off with a positive reputation.
You can get 806 ci out of a 460 but not the 454.
Old 11-08-2005, 08:09 PM
i might have to check that out.
is that the only reason the 460 is more capable? i would tend to think of the 454 as the more capable one considering its aftermarket size compared to the 460. heck, the engines are probably about identicle anyways aren they?
Old 11-08-2005, 08:22 PM
DOHCmarauder's Avatar
DOHCmarauder DOHCmarauder is offline
DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.DOHCmarauder has a great reputation on FTE.
There's a lot of pro's con's to each.......Off the shelf, factory produced, they're pretty close. I've owned both at the same time and the Ford seemed more durable for me....but of course you'll get many GM owners telling you the opposite.
People will whine about the 454's rod ratio, the 460's oiling system, the 454's port layout, the 460's lack of head bolts, the rarity of 4 bolt mains on the BBFords, Chevy's cracking exhaust manifolds..................... and on and on and on.
But unfortunately, unlike the smallblocks where Ford has really closed the gap as far as affordable aftermarket parts, the BBchevy is waaaay cheaper to make go faster.
Just check out the Marine industry as an example.
That doesn't mean the BBFord can't compete...........IHRA mountain motors are an example where Fords are dominating........but on a HP per $$$, the BBC has the upper hand.
Old 11-09-2005, 02:37 PM
Kenworth Kenworth is offline
Kenworth is gaining momentum as a positive member of FTE.
The 460 was known for more of a work horse engine not a racing motor the 429 was more of Fords BB hotrod.
The reason why the marine industry uses Chevy is the engines are lighter look at Ford they use heavy blocks etc a 460 is quite abit heavier than the 454. Another reason is Chevy engines were plentyfull and cheap also chevy was more open to sell their engines for other uses.
The new marine engine is the 496-502 gets better fuel economy more power and lasts longer compared to the 454.
Old 11-09-2005, 06:34 PM
The real reason the marine industry uses mostly Chevy engines is because the 3.0L 4 cylinder, 4.3L V-6, 5.0L, 5.7L, 7.4L, and 8.2L V-8's all had the same bell housing bolt pattern. A 460 and a 454 weigh about the same.
Old 11-09-2005, 06:59 PM
Anyway, the 454, 496 and 502 are all basically the same motor.
Interchangability has a lot to do with it, i agree, Joe.........but the fact remains; a BBC is cheaper and easier to make go faster than a BBF.
Kurt's 1954 F-100 Labor of Love Michael Levy 1948 - 1956 F1, F100 & Larger F-Series Trucks 46 02-01-2016 08:30 AM
Proformance Expedition Ford'05HG Expedition & Navigator 10 11-03-2013 05:10 PM
Tri-power Question ? Kurt G. 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 06-16-2003 11:06 PM
F350 vs. F250 What's the difference ?..Please Kurts50 1999 to 2016 Super Duty 13 12-07-2002 05:54 PM
Does your interior have lots of squeaks and rattles? Kurts50 1999 to 2016 Super Duty 4 10-20-2002 05:33 PM
Tags
350, 454, 460, 496, 57, big, block, chevrolet, chevy, compare, ford, fords, motorhome, versus, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
