Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-06-2005, 12:19 PM
milesperhour79 milesperhour79 is offline
Garage is empty, add now
milesperhour79 is starting off with a positive reputation.
Question 1970 C-850 w/ 534 & 1978 C-800 w/ 477
I'm a new member to the board and a fairly new owner to the two fire engines stated above. The '70 ran like a champ when I bought it, but now it won't start. We suspect it's electrical and plan on doing a complete tune-up (plugs, wires, cap, rotor, points and condenser). We might even check the timing.
The 1978 runs great, but I've recently noticed that it shifts a little harder than it originally did. Any ideas on what might cause this or what I should check?
I'm so-so when it comes to vehicle issues, so any help/advice that anyone could provide on either truck would be a great help! They don't seem too complicated, but I hope to learn a lot from being a member of FTE. Thanks a bunch!
-Mike
P.S. I've read a lot of threads requesting engine pictures. If any one needs/wants, let me know. I'll take them all day long! :-) (however, it just might take a few days to upload them)
  #2 (permalink)
Old 11-08-2005, 05:35 AM
Still in the 60's Still in the 60's is offline
Still in the 60's is starting off with a positive reputation.
I have a couple of C- series, a 62 C850 fire engine w/534, a 74 C750 w/391. and find that keeping the shift linkage greased is the major point. Also, there are 2 (I think) bushings that support the shift shaft as it comes from the front of the truck back to the tranny. Be sure these and other linkage points are not worn. It is possible that hard shifting is due to wear in the transmission top cover (shift rails etc) but start with the easy stuff, like the grease gun.
I would love to see photos of your trucks, got to figure that out myself!
  #3 (permalink)
Old 12-13-2005, 09:30 AM
Thumbs up
Sorry it took so long to get back, but the grease gun worked! Thanks a bunch for that simple advice!
I'm actually selling the 477 on eBay (the 534 is good enough to own), so there are some pictures on there if you would like to check them out: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ru=http%3A%2F%2Fsearch.ebay.com%3A80%2F%2Fsearch%2 Fsearch.dll%3Ffrom%3DR40%26satitle%3D4596334219%26 fvi%3D1&item=4596334219
If the link doesn't work, just go to www.ebay.com and search for 4596334219.
As far as the other truck goes, it turned out to be a loose wire going from the coil to the distributor along with the spark plugs. I replaced distributor, cap, rotor, condenser, points and plugs. I also had the carb rebuilt. The thing runs great! Heck, I might even get better gas mileage now!!! LOL
Mike
  #4 (permalink)
Old 02-16-2006, 12:54 AM
ron_29_1973 ron_29_1973 is offline
ron_29_1973 is starting off with a positive reputation.
anyone interested in a 1958 ford c800 with a new 391 4v ????
Tags
1960, 1970, 477, 534, 800, adjustment, c800, c850, cap, distributor, engine, ford, linkage, shift, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
