Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
  #1 (permalink)
Old 11-06-2005, 12:16 PM
Agent Iron Agent Iron is offline
Garage is empty, add now
Agent Iron is starting off with a positive reputation.
Shift indicator does not match actual gear.
When I purchased my my 97 aerostar the gear indicator said reverse when you were in park. Now the indicator says 2 when you are in park. I still have all my gears, but things don't match up. I tightened the torx bolts that hold the bracket which connects the shift cable under the column, but they were plenty tight. I lubricated the cable as it has always been stiff to shift, but this made no difference. What other variables are there? What else can be moved in order to allow the column indicator and transmission to match? I can't find any adjustment at the trans. I tried to loosen the large 19mm nut that mounts on the shift lever at the trans, but it does not want to move, and was half afraid if it actually did. I don't know how that would make any difference anyhow.
Help
Thanks
Jay
Tags
2000, explorer, f150, ford, gear, gears, indicator, match, operation, shift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
