Summer fuel in 97 now won't start....
So, what the hell do I do now? I took the filler spout off my tanks and can see the gel in there. I bought some diesel additive that claims to keep diesel thawed and bla bla bla, but even after running a heater under the truck all tarped in for 2 hours I couldn't get things warm enough to flow. I can't even get the filter to drain.
I have a fuel filter light come on and a water in fuel light, but like I said the filter pot won't drain. I suppose if the fuel pumps are stiffened up then no fuel is making it to the engine huh?
If I can get this thing into a warm garage overnight and get it running, short of running it all day until the fuel is gone, how do I deal with the summer fuel?
I hate not knowing how to deal with things.........
Once it's ungelled the additive that you already added should keep it from regelling. Power Service has a product called diesel 911 that's only purpose is to get a gelled truck up and running. It's normally on the shelf at Wal-Mart along witht he rest of the diesel fuel suppliments.
Pour some anti-gel straight into the filter bowl to help get it running. Once it's running the engine heat will clear whatever residual gelled fuel remains.
Thanks for the advice. Walmart, only a 4 hour drive, I better check Napa. I see you told another fella that this forum can walk a guy through any problem. Well after I get into this truck a bit more you may want to recant your offer! I may bombard you with enough goofy questions that you'll ask me to take a time out!!
Adam
Adam
ryanbodden2014
6.4L Power Stroke Diesel
02-11-2015 09:43 PM
Skagit
02-15-2004 06:27 PM
