Serpentine Belt Coming off? - Ford Truck Enthusiasts Forums
Old 11-04-2005, 05:56 PM
getrdone getrdone is offline
getrdone is starting off with a positive reputation.
Question Serpentine Belt Coming off?
I have a 1990 f-150 V-8 5.0. Lately the serptine belt has been sliping out of alignment on the AC compressor pully. it doesnt totaly come off but about half way.
Is there a way to prevent that or tighten the tensioning spring?
Old 11-04-2005, 06:02 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
You have a pulley out of whack somewhere. Did this just start after you replaced an accessory? It could be the tensioner going bad, too.
Old 11-05-2005, 02:07 PM
ya i just replaced the alternator. but when ever i pull back on the tensioner its really easy to pull on it. I usually have to use two hands and walk around to the side of the truck. Lately i can do it with one hand.
Old 11-05-2005, 10:34 PM
92lightning 92lightning is offline
92lightning is starting off with a positive reputation.
Sounds like the tensioner is going bad.They are not to expensive and that should take care of the problem.
Old 11-06-2005, 12:39 AM
92CajunExpress's Avatar
92CajunExpress 92CajunExpress is offline
92CajunExpress is starting off with a positive reputation.
Check pulleys as well
A new tensioner is a good start but Check Your pulleys as well.
I had a issue like this on my F-150 (4.9 I-6).When I replaced the tensioner my belt was still coming off due to the water pump trying to freeze up.
Old 11-06-2005, 07:17 PM
how much would a tensioner run for? (im a teenager with very little money)
'93 7.3 IDI has noisy serpentine belt nbtone Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 05-11-2016 10:36 AM
serpentine belt problems.. help please powerstroker100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 07-10-2015 03:46 PM
Turning off seat belt nag warning jasonnerothin 2004 - 2008 F150 5 10-04-2011 08:24 PM
belt slap IDI Diesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 01-01-2011 03:53 PM
how to disable seat belt alarm? mpbpulaski 1999 to 2016 Super Duty 9 02-27-2005 02:38 PM
Tags
1986, 1990, 302, 96, belt, coming, comming, e250, f150, falling, ford, serpentine, slipping, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
