475 Super duty?
There definitely was a 475. Don't take this as Ford gospel, it is just my understanding. It first showed in 1974 in the 880 series trucks as a lower cost version of the 477 to respond to the GM 427 truck engine. The F & L-880 trucks were offered from 74 to 77 when the 880 's were rolled into the 800 series trucks.The 475 was essentially the same as the 477, but it did not have the 100,000 mile factory Super Duty warranty. I am told it also had a different crankshaft, but that point I am not certain of.
It was marketed as a lower cost medium duty engine rather than the higher priced Super Dutys.
By now however, diesel was closing the door on the big gas burners, but they still are a lot of fun!
Welcome to FTE.
Looks like:
https://www.sparkplug-crossreference...t/AUTOLITE/824
The 475 is a smog version of the 477, if that makes it easier to find things.
Good luck with it!
Looks like:
Good luck with it!
I found one on line at NAPA. When you put your vehicle info in, change the vehicle type to "medium/heavy".
https://www.napaonline.com/en/search...=nol-veh-conds
