oil pan capacity in 73 Econoline 400 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 11-03-2005, 08:13 PM
smoove_d smoove_d is offline
smoove_d is starting off with a positive reputation.
I have a 400 from which the oil pan (rear sump)decodes to have come from a 73 Econoline with a 400. Does anybody know the capacity(with filter)?
Old 11-03-2005, 08:32 PM
ColonyPark ColonyPark is offline
ColonyPark is starting off with a positive reputation.
I can't answer that, but I can tell you that it might be a large capacity. The 351M I had in a 1980 Econoline had a capacity of something like 8 or 9 quarts. I always had to double check the grease monkeys who inevitably underfilled it.
Engine rebuild problem smoove_d 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 03-11-2006 03:19 PM
main bearing problems in new rebuild smoove_d 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 15 11-11-2005 06:16 PM
decode oil pan numbers smoove_d 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 10-31-2005 08:34 PM
300 w/AC to 400 smoove_d Engine Swaps 1 06-04-2005 05:14 AM
400 water pump inlet smoove_d 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 04-15-2005 09:00 AM
Tags
1983, capacity, econoline, ford, in73, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
