Ford Factory 7way (RV) plug ?
I replaced the 4way flat plug with the Ford Accessory 7-way round plug on my 2004 Ford Heritage SCAB 4.2. Everything works except the trailer battery charging circuit. I have checked all the underhood fuses that are indicated in the owners manual. Am I missing a fuse or switch.
Thanks
Thanks
On my supercrew, the charging circuit is live as long as the ignition is in the "on" position.Is this truck equipped with factory tow package? If it is the charging relay may not be in the fuse box under the hood. All factory tow package trucks come with two relays and a harness in the glove box, 1 relay is for the brake controller and the 2nd relay is for the charging line to the connector at the hitch and the harness is to connect your brake controller to the truck via a harness next to the steering column. If your truck is not factory towing, then you will need to add the charging circuit to the connector at the hitch. Hope this helps!
Goon
Goon
I checked my underhood fuse and relay box and i am missing the charge relay for the trailer system. Thanks for steering me I checked the fuses which I have but, not the relays. Thanks I will be visiting the dealership as they look to be unique ford relays not a bosch standard five or four plug.
Chad311
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
05-26-2015 04:54 AM
drewk4
01-31-2010 01:04 PM
