"2"-ning a 292
Old 11-03-2005, 03:23 AM
58tow's Avatar
58tow
58tow is offline
Unhappy "2"-ning a 292
I've read diagnostic questions of other members in refrence to tuning a 292, and found that we share simliar problems, my 292 is running , Idles fine while cool, but backfires when warm or under a load in high gear(load meaning ...hill's,etc), some of the things I've done to try and correct this problem ,replace the distributor(with rebuilt) rebuild the carb (twice, just to be sure) and I'm in the process of making adjustments to the , points, adding new spark plugs and wires double and triple checking timing. And just to be sure, begging for help with firing order, timing marks, plugs to use, wires to use, gap settings for plugs and points, and any other usefull information I can gather from the "Y - block Gods" here at FTE, thanks all in advance, .....58tow
Old 11-03-2005, 11:37 AM
Sam_Fear's Avatar
Sam_Fear
Sam_Fear is offline
Sounds like it may be that you're spark advance isn't quite right. Here's a link to a short primer that might give you some ideas:
http://m571.com/yblock/advance.htm
This is a page about tuning the distributor:
http://m571.com/yblock/distributortuning.htm
And I guess I should add the link tohis home page too:
http://m571.com/yblock/index.htm
Old 11-03-2005, 09:07 PM
46yblock's Avatar
46yblock
46yblock is offline
Welcome to FTE! Plug gap .035, point gap .014 - .016, timing 8-10 degrees, plugs Autolite 46, firing order 15486372, front passender cylinder #1, front driver side cylinder #5.
Things to thing about: Crossfiring between plug wires, hookup of distrbutor to proper vacuum fitting on carb, worn timing chain/gear, shift of timing mark on damper due to rubber deterioration, vacuum leak, valve lash adjustment. Maybe one of the guys will get it more narrowed down for you.
Mike
Old 11-18-2005, 11:47 PM
f700's Avatar
f700
f700 is offline
did you check your valve ajustment ?
interceptor1
20
10-31-2006 05:22 PM
AzPete
03-16-2006 05:11 PM
Phity Five
10-27-2005 02:36 AM
F250Rob
19
07-31-2004 10:01 PM
F250Rob
07-28-2004 05:38 PM
Quick Reply: "2"-ning a 292
