Blinking Overdrive light (on/off) on gear shift
11-02-2005, 08:12 AM
on
My overdrive light on the gear shift keeps blinking and it is for certain I am out of overdrive. And my check engine light came on. Any ideas.
11-02-2005, 08:15 AM
on
Check the switch it a very common problem with all fords. Just make sure that it operates.
11-02-2005, 08:11 PM
on
I had the same problem in my excursion. I replaced the speed sensor in the rear differential and the problem was solved. Hope this helps.
11-03-2005, 07:33 AM
on
could also be a shift pack solinoid going bad. get it scanned by shop of your choice and let use know what the code is.
BriR
1997-2006 Expedition & Navigator
18
04-16-2021 09:08 PM
Black Betty 7.3L
10-24-2016 08:13 PM
patsalters
09-11-2013 09:43 AM
jonnyboy78023
18
03-24-2008 11:00 PM
tfrazee
1997 - 2003 F150
54
03-23-2004 06:24 PM
