Distributor Stuck in 351M Please help! - Ford Truck Enthusiasts Forums
Old 11-01-2005, 09:05 PM
93redneck150's Avatar
93redneck150 93redneck150 is offline
93redneck150 is starting off with a positive reputation.
Exclamation Distributor Stuck in 351M Please help!
I went to adjust the timing on my 1977 f-150 and found that the distributor is stuck in the block. The clamp comes off but the distributor will not turn in the block. I have been soaking it with PB Blaster and Kroil and still no luck, I have tried tapping it with and small hammer etc... Does anyone have any tricks on getting it loose? i dont want to hit it too hard because i dont want to crack it.
Thanks
Dave M
Old 11-02-2005, 01:48 PM
The Shadow The Shadow is offline
The Shadow is starting off with a positive reputation.
Yeah, okay, first: settle down. Next, Take a red rag fold it into fours and wrap it around the dizzy shaft, and then take a pair of vice grips, clamp them as hard as you can (with two hands!)around the rag over the dizzy shaft. When you are sure that there is no way that they will slip off and the grips themselves are at a 90 degree angle in proporion to your motor, take a hammer and start tapping gently back and forth in the outward most part of the handles. As you are doing this, progressively tap harder while alternating left to right. This works, I've done it a million times and it works almost every time. The only time it does'nt work is when the dizzy is absolute junk and you have to heat up the shaft with ox/acetylene to get it out. If you end up having to do that throw the dizzy away. The casting is the flimsiest cast aluminum ford could find and it will undoubtedly be warped afterwards. Hooray for M-blocks!! BTW- "M" really does stand for modified, as in: "Modified Cleveland" it is in the Ford factory literature, look it up!
Old 11-02-2005, 02:22 PM
kopfenjager's Avatar
kopfenjager kopfenjager is offline
kopfenjager is starting off with a positive reputation.
Yes but they never threw an M on the 400, and it was out for 5 yrs before the 351M. The M was there just to distinquish between the C, and the W. Call it what you will. Literature was written by marketing, not engineers.
Old 11-02-2005, 07:03 PM
crawlfish crawlfish is offline
crawlfish is starting off with a positive reputation.
There is one sure, safe method that I used after asking around here and after cracking my distributor trying every other possible manner of freeing it. It got my cracked distributor out easily and saved me from ruining a second stuck one from a donor engine:
Soak well (days) like you've already done with your favorite miracle penetrant.
Take the oil pan off, remove the oil pump.
Tap the hex drive that goes from the distributor to turn the oil pump from the bottom up to the distributor.
A few good center taps should pop it right out, I tapped with increasing force and it got mine.
Like I said wish I'd known about it earlier because it would have saved me some grief and kept me from damaging that cast metal.
Old 11-02-2005, 10:40 PM
Thanks for all of the advice. I will give it a try tommrow and post how i make out with it.
thanks
Dave
Old 11-03-2005, 09:11 PM
Half way
Quote:
you know, this is the most plausible explanation I've heard yet... it's half way between the c and w... i can hear it now... well, let's just split the difference!
Old 11-05-2005, 01:25 AM
Thats a good one!
Old 11-05-2005, 04:44 PM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
reaching for my ACME All-in-One Super Duty Vitamin Fortified Patent Pending Thread Locking Device...
Old 11-05-2005, 06:50 PM
I want one of those too, the feeling it must bring...
sorry though... I'll try to be better really i will...
Old 11-05-2005, 07:03 PM
Hey redneck, did u ever get your distributor out?
Old 11-06-2005, 09:09 PM
It's Still stuck in there!
Nope it's still stuck in there!
We've tried the vise grips idea, a hammer, a bigger hammer, and air chisel, a bigger air chisel, and it still doesnt want to budge. i've got it soaking with all sorts of penetrating oil for now and were gonna try it one more time with the air chisel tommrow but I think we might end up having to try and heat it up and then replace the ditributor. one of my buddies has an extra he'll give me so that might be what i end up doing.
I'll let everyone know when i get it out.
thanks for all the help
Dave M
Old 11-06-2005, 09:13 PM
Options
Did you try knocking it out from underneath?
Old 11-07-2005, 08:19 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE.danlee has a good reputation on FTE.danlee has a good reputation on FTE.
I have had some success with a flat nail puller under the flange on the dizzy. Just tap it in with a hammer, and then using the puller leverage, tap on the puller to drive the dizzy up. If you can get it to move just a little spray penetrant in the joint. Then leave it sit and try all methods again later.
Old 11-09-2005, 10:01 AM
Nigel Nigel is offline
Nigel is starting off with a positive reputation.
I soaked mine for weeks with PB with no luck at all. We tried everything then finally removed the oil pan and oil pump and pounded it up from below. the distributor was a write off which did not matter to me as the point of this was to put an msd unit in anyway. If they don't want to come out they can really mean it.
Old 11-12-2005, 09:53 AM
smoulding smoulding is offline
smoulding is starting off with a positive reputation.
Mine was stuck, was soaking for 'months' with penetrant. I beat on it with a hammer and pry bar (broke the distributor, don't do this!!). It threw the timing off so much it wouldn't run, and I couldn't re-adjust it. I ended up pulling the 400M engine and rebuilding it, but that distributor was practically welded stuck. I got it off by removing everything in my way 'braces, ect'.., clamping the largest vice grips I could find on the shaft, and using a pipe on the end of the vice grips just to get it to move. It took that much! Even with that, it took several times moving back and forth before it would finally pull out. What a hassle!!! I'd swear it was welded on there, but it wasn't. Just stuck from sitting for 25 years without being moved. Got a MSD setup now, including distributor. I'm kinda glad I broke it. Runs great now!
390 FE Distributor stuck when warm... Old Brown F250 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 03-08-2012 07:01 PM
How do i remove a stuck distributor torque head 1978 - 1996 Big Bronco 9 05-28-2010 11:51 PM
distributor stuck scottddove Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 08-02-2008 02:12 AM
351M Distributor stuck 1979 F150 4X4 1979F1504X4 1973 - 1979 F-100 & Larger F-Series Trucks 12 05-23-2003 04:41 PM
distributor frozen in block 78Bill 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 7 09-08-2002 04:03 AM
Tags
distributor, move, msd, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
