1990 5.0L Firing Order - Ford Truck Enthusiasts Forums
Old 11-01-2005, 08:51 PM
TheRoadVirus TheRoadVirus is offline
TheRoadVirus is starting off with a positive reputation.
What's the firing order on my 1990 F150? It's apparently been converted to a Mustang GT computer, but I can't verify that for sure. I do have the old computer in my closet, though. (The old owner gave it to me..)
The reason I'm asking is because with the Ford Racing MAF conversion kit I'm buying won't it be using the Mustang firing order? Which if I'm not mistaken is different from my truck? How does that work.. Also; does anyone know which tuner I should buy after doing this conversion.. should it be the mustang one or for my truck.. SCT Xcal 2 is what I'm looking at.
Thanks.
Old 11-02-2005, 12:42 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Truck firing order is 1-5-4-2-6-3-7-8. The mustang computer is set up for the 1-3-7-2-6-5-4-8 order. The kit wires the truck injectors so that they fire in sequence with the truck firing order (switches 3 & 5 and 4 & 7). If you tune the MAF computer, it will need to be for that computer, not for the truck. Blurry94 knows much more about the tuning aspect than I do.
5.0 mustang / Lincoln town car 5.0 the same? 50SICKS Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 12-06-2013 10:24 AM
SD to MAF conversion firing order question menesesjesse 1987 - 1996 F150 & Larger F-Series Trucks 23 11-07-2012 11:57 PM
Blew a head gasket :( Beatertruck 1987 - 1996 F150 & Larger F-Series Trucks 7 10-23-2011 12:00 AM
Injector firing order wayneF250 1987 - 1996 F150 & Larger F-Series Trucks 7 12-10-2007 08:24 PM
ford f150 5 liter high output mustang engine conversion logman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 09-18-2006 12:24 AM
Tags
1990, 1990n, 1997, 302, 50, 50l, explorer, f150, firing, ford, gt, mustang, order, straight, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
