Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2005, 07:28 AM
scole250 scole250 is offline
scole250 is gaining momentum as a positive member of FTE.
Max run time/duty cycle for a diesel
What's the max amount of time you can continuously run a diesel engine? Not talking about a PSD. I'm referring to diesel engines on backup generators. The 50-100kw size. How many hours can they be run before you have to let them cool down, service, etc?
__________________
2005 F250 SD Lariat CC SRW 6.0 4x4
2003 Escape V6
  #2 (permalink)
Old 11-01-2005, 07:42 AM
4wd 4wd is offline
4wd is starting off with a positive reputation.
As long as the load is sized within the engin's continuous duty hp ratings, it is designed to run continuously---forever.
I don't believe I have EVER seen a continuous duty hp rating for the 6.0 diesel.
__________________
'05 F-350 4x4, V-10, 6spd, 4.30 LS, 18" rubber;
Farming;
SW Iowa
  #3 (permalink)
Old 11-01-2005, 08:55 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Quote:
If you could figure out a way to change the oil, coolant, filters, etc while the engine is running you would never have to shut it down. If you are in a situation that absolutely requires non-stop power, like a hospital or something, then I would imagine you have to have more than one generator anyway.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
Rest in peace, Todd. We will meet again.
  #4 (permalink)
Old 11-01-2005, 01:48 PM
guthrie&co's Avatar
guthrie&co guthrie&co is offline
guthrie&co has a good reputation on FTE. guthrie&co has a good reputation on FTE. guthrie&co has a good reputation on FTE.
Quote:
you could use a oil filter relocation kit and use 2 filters. a few valves thgat way you could switch the oil flow to the other filter.
as for changing the oil.....i would say they you could set up a sytem that would drain the used oil and fill it at the same time. although you would have to drain and fill at the same rates. possibly fill faster than drain.
__________________
Daniel
In 2010, The United States will start to deport retards. My eyes started to water when I thought of losing some of you. Love you. Be strong and take your crayons
  #5 (permalink)
Old 11-01-2005, 02:36 PM
Jesus spoke a lot
1999 Ford F-550
So what is your situation anyway? I'm curious why you want to know how long to run the gen without shutting off.
__________________
Dan
  #6 (permalink)
Old 11-02-2005, 05:16 AM
Crash687's Avatar
Crash687 Crash687 is offline
Crash687 is gaining momentum as a positive member of FTE.
almost all diesels have a large enough oil sump that you can do part oil changes, probably best to have it tested to determine change intervals. replace any of the filters with a dual remote setup that you can valve off each filter individually and don't forget about a an air vent for the fuel
__________________
FTE "the best, why mess with the rest?"
just so you know what time it is
Help cure Cancer
'05 F-350 PSD work truck
If electricity comes from electrons, does morality come from morons?
  #7 (permalink)
Old 11-02-2005, 05:29 AM
I'm not interested in running a diesel forever. I'm just trying to find out how long you can run a diesel, on say a 100kw generator, before you have to shut it down for maintenance. 24 hours, 50 hours, 100 hours, longer?
__________________
2003 Escape V6
  #8 (permalink)
Old 11-02-2005, 07:31 AM
Jesus spoke a lot
1999 Ford F-550
Depends on a few factors. Like oil sump capacity. The bigger the sump, the longer you can run it. In your case I would want to use synthetic oil and a bypass filter. Big rigs can go 100,000 miles without changing oil that way. Perhaps consider a dry sump system and switchable tanks. That way you never have to shut it down unless something broke.
I don't know where you live, but you may want to check into neighborhood noise abatement rules. I would be VERY irritated at a constant engine noise while I am trying to sleep, and would be doing something about it.
__________________
Dan
  #9 (permalink)
Old 11-02-2005, 09:13 AM
Thanks, I'm a good neighbor though. I'd only try it somewhere suitable.
__________________
2003 Escape V6
  #10 (permalink)
Old 11-02-2005, 02:30 PM
efoster_01's Avatar
efoster_01 efoster_01 is offline
PREMIUM SPONSOR
efoster_01 is starting off with a positive reputation.
this was along time ago, but my uncle used to work for A railroad, dunno which one, but he said the generators were never turned off, not even for oil changes, they let them run non stop and rebuilt them every 2 years which works out to be 17,520 hours of continous operation on the same oil. but fuel was cheaper then, he said they stopped doing that in the late 60's.
Bone
__________________
2008 6.4L f350
Evan Foster
  #11 (permalink)
Old 11-02-2005, 09:53 PM
2003 6.0's Avatar
2003 6.0 2003 6.0 is offline
2003 6.0 is starting off with a positive reputation.
At my last job we ran our generators 24/7 for seven months straight. We changed the oil, oil filter, and inline fuel filter once a week. We could have ran them longer without service but its cheap insurance to keep the fluids clean.
  #12 (permalink)
Old 11-04-2005, 02:36 PM
WWBeast's Avatar
WWBeast WWBeast is offline
WWBeast is starting off with a positive reputation.
how long do yall think a PSD could run for
__________________
05 F-250 Lariat 4x4
SCT X3 Innovative Tunes
35 inch Procomp Xtreme AT
6 inch Procomp Stage II lift
MBRP 4 inch Straight Pipe
  #13 (permalink)
Old 11-04-2005, 03:32 PM
Customz's Avatar
Customz Customz is offline
Customz has a good reputation on FTE. Customz has a good reputation on FTE. Customz has a good reputation on FTE.
Probably 300 continuous hours. I think that is the recommended oil change interval.
__________________
2006 F-250
  #14 (permalink)
Old 11-04-2005, 06:56 PM
jwearly jwearly is offline
jwearly is starting off with a positive reputation.
From my days in the USMC we ran generators constantly for 7 days before changing oil and filters. We used 7 days because it was easy to compute from start up to change.
Once ran a 100kw 6 cyl CAT 21 days with no damage just a hell of a lot of fuel.
__________________
J. W. "Snake" Early
Houston, TX
2002 F250 Lariet CC, LB 7.3 L PSD
  #15 (permalink)
Old 11-08-2005, 05:18 PM
farmtwuck farmtwuck is offline
farmtwuck is starting off with a positive reputation.
It depends on the recommendations of the engine manufacturer. However, most of these recommendations are developed for cyclic use such as in a tractor - something that is started and stopped on a "frequent" basis.
A diesel engine on a generator is almost the perfect application for long engine life. Nearly contant RPM, which yields fairly constant temperature and infrequent start ups. You can probably excede the manufacturers recommendations and be fine.
I have seen many diesel engines in a pumping application where they are started and shut down once a month for maintenance. That's 720 hours on an oil change. As for lifespan on these engines? 50,000 - 60,000 hours was common. I personally know of a couple of instances where the engine ran for over ten years in constant use (shut down for maintenance once a month, sometimes more often for other repairs) without a major overhaul. The engines I'm talking about are small air-cooled engines made in England by Lister. Absolutely amazing engines.
There used to be some Lister factory literature available where they had gensets being used in the Arctic. Something to do with the early warning system. If memory served me correctly they ran for something like 13 years straight - never shut down. They had a large oil sump system like some of you have described. I won't swear by this information since it's been several years since I saw the flier.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
