Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2005, 08:04 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Shell Rotella ELC coolant
The coolant return flange is leaking a good one on my truck. I ordered some Shell Rotella ELC coolant to fill it back up. That doesn't need the additive like the green stuff does it?
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #2 (permalink)
Old 10-31-2005, 08:28 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold
Nope, not according to their website.
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6 with a shorty shifter, NV271, -38R, SII splits, Adrenaline HPOP, DI tunes, ITP fuel, 5" stacks, IDM140, ARP studs, 6637, Autometer gauges. 17x10 MB wheels 35" BFG AT's.
  #3 (permalink)
Old 10-31-2005, 08:29 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
youre not going to mix green with gold, are you? i am almost positive you have to flush green out as best as you can before adding the gold, which does not need additive. which do you have in there now?
__________________
2002 F-350 with some mods, current best 12.8 @ 104 Fuel only
Spooled, Fueled, and Tuned by Swamps Diesel Performance, Trans by BTS, Engine built by me
Swamps gives me enough power to break a BTS
  #4 (permalink)
Old 10-31-2005, 08:32 PM
cookie88's Avatar
You can mix the green with the gold, but you have to treat it like it's green.
__________________
  #5 (permalink)
Old 10-31-2005, 08:47 PM
2002 Ford F-350
ahh gotcha. so if you dont want to add the additive it has to be gold 100%?
__________________
  #6 (permalink)
Old 10-31-2005, 08:53 PM
cookie88's Avatar
Exactly...
__________________
  #7 (permalink)
Old 10-31-2005, 10:31 PM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
http://www.shell-lubricants.com/prod...RotellaELC.pdf
Still have to add the SCA's like cookie mentioned.
__________________
'01 F150 5.4L 4x4
  #8 (permalink)
Old 10-31-2005, 10:58 PM
Jesus spoke a lot
1999 Ford F-550
Looks like the good stuff. Thanks for the help gentlemen. I am going to completly flush out the green goo and go with a complete fill when I get the leaky gasket fixed. It's just the coolant return flange that bolts to the bottom of the water pump. I've been seeing little drops coming down for a few weeks now. Coolant use has started to go up so now I have to do something about it. Been putting it off because the coolant that is in there is less than a year old.
__________________
Dan
God and Dog
  #9 (permalink)
Old 10-31-2005, 11:28 PM
BadFord99's Avatar
BadFord99 BadFord99 is offline
BadFord99 is starting off with a positive reputation.
ROTELLAŽ ELC Extended Life Coolant/Anti-Freeze is a "fill for life" ethylene glycol based coolant for heavy-duty diesel, gasoline and natural gas powered engines. Rotella ELC contains a unique extended life carboxylate inhibitor system and nitrite / molybdate as secondary inhibitors. This product contains no silicate, borate, nitrate or phosphate and requires no traditional SCA additions. Rotella ELC Extended Life Coolants meets all the requirements of CAT EC-1, TMC RP 329 and TMC RP 338. Rotella ELC is available as a concentrate and as 50/50 and 60/40 volume mixtures of Rotella ELC with deionized water.
This is the info directly from their site.
__________________
"Keep on Powerstrokin"
  #10 (permalink)
Old 11-01-2005, 12:15 PM
Before changing over to the Rotella ELC, I contacted a list of several non-biased AF testing facitlities, and every single one of them confirmed that the Rotella ELC was "the" coolant to run in terms of cost and overall life and protection.
When I filled my truck 7 months ago, it cost me a little over $11 per gallon of concentrate at NAPA.
I'd reccomend installing a coolant filter if you haven't already....this is something that I failed to do, and wished that I did.
__________________
'01 F150 5.4L 4x4
  #11 (permalink)
Old 11-01-2005, 12:29 PM
Jesus spoke a lot
1999 Ford F-550
Good idea! Thanks.
__________________
Dan
God and Dog
  #12 (permalink)
Old 11-01-2005, 02:44 PM
westladog westladog is offline
westladog is starting off with a positive reputation.
Man! I still have two gallons of the Prestone Heavy Duty Antifreeze/Collant left. This Rotella ELC looks to be a better performer than the Prestone Heavy Duty. What color is the Rotella? The Prestone is "purple".
  #13 (permalink)
Old 11-01-2005, 06:25 PM
It's a deep red color.
__________________
'01 F150 5.4L 4x4
  #14 (permalink)
Old 11-03-2005, 11:32 AM
89LX306 89LX306 is offline
89LX306 is starting off with a positive reputation.
I've been using the Rotella ELC and a coolant filter now for about 20k miles. I've been very pleased with it. My truck is a 2002 and originally had gold. I lost a water pump at 73k miles with the original fill of gold. I've now got 115k on the truck.
Reminds me...I need a couple more coolant filters.
  #15 (permalink)
Old 11-03-2005, 08:51 PM
01stroker's Avatar
01stroker 01stroker is offline
01stroker is starting off with a positive reputation.
Quote:
Hope it don't turn out like mine, had to rebuild it. Seal was leaking.
__________________
01 F-250 Super Duty SB PSD, auto, 3.73 gears. All stock except SCMT tow safe, Ford severe duty AIS, Shortened filler vent pipe, CCV mod, Fuel tank pickup and pre-pump mods. Running on Homebrew Biodiesel.
Tags
97 , 99 , changing , coolant , coolent , diesel , elc , f350 , ford , green , heavyduty , package , powerstroke , red , rotella , sca , shell , towing , truck , wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
