Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 11-11-2007, 11:53 PM
guitarpicr's Avatar
guitarpicr guitarpicr is offline
guitarpicr is gaining momentum as a positive member of FTE.
Online try "Blains Farm & Fleet " - $10.99 Gallon - 50/50 mix
__________________
Bill - 02 -F250 Lariet 7.3 PSD- SB -X Cab 2 wd - 700 Leer Lid - Billet Grill - Alum. Rear diff.- CCV and 6637 w/ Pete cover-Fumoto-Isspro 3 gauge pillar -Tru-cool max - SS HPX - Silverline 4" SS Exhaust- Hutch & Harpoon -JWVB- Rear air bags-26' -8500# trailer- Prodigy "Mans Got to Know His Limitations"
  #47 (permalink)
Old 01-07-2009, 07:27 PM
Bowie Bowie is offline
2003 Ford F-350
Bowie is starting off with a positive reputation.
So I am dumb. The coolant that came with my truck is gold. Is it suppose to last the life of the truck? Should I change it?
__________________
Kyle
2003 F350 Lariat 4X4 Auto, 6" lift, 35 toyo mudders, 4" exhaust, 6637, 6.0 Tranny Cooler, Live tuned DP Tuner (45mph valet, Drive Thru, 40 tow, 60 tow, 80 tow, 60 Econo, 80 Econo, 100 perf, 120 race, 140 Extreme, 140 Aggressive), BTS VB, WW, HPX, FRX, Bellowed UP-pipes.
  #48 (permalink)
Old 01-07-2009, 08:10 PM
sgrol sgrol is offline
sgrol is starting off with a positive reputation.
Quote:
Yea, if its been in there since 2003, I would definitely change it. I would not risk my expensive engine on 'claims' of a lifetime coolant. Put in a good coolant like the Shell ELC and install a coolant filter and you should be set.
__________________
Steve
2000 F 250 7.3 Powerstroke, 4x4, CC, AFE Stage II, MBRP 4" turbo back, 6 Pos DI Chip, IAH delete, Guages, CCV Mod, A.E., Tru-Cool, Vacuum Htr bypass, HPX, EBPV gut, WW, marine turbo boots
2001 Ram 2500 5.9L 24 V - nice engine
  #49 (permalink)
Old 01-07-2009, 10:11 PM
Orezona's Avatar
Orezona Orezona is offline
No Signature/No Agenda
Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE. Orezona has a very good reputation on FTE.
Wow, congrats to you two for using the search and reviving a 3 year old thread.
__________________
  #50 (permalink)
Old 01-07-2009, 10:48 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
Quote:
Agreed, beats the heck out of responding to a question that has been asked, and answered. Oh, you mean the part about posting when the answer was found?
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #51 (permalink)
Old 01-07-2009, 10:56 PM
Orezona's Avatar
Yes.
Hey, my sig shrank...or shrunkteded, or got smaller, or shrunk...
__________________
  #52 (permalink)
Old 01-07-2009, 11:01 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel is gaining momentum as a positive member of FTE. Fat Diesel is gaining momentum as a positive member of FTE.
Yes.
Hahaha. Sounds like a personal problem!
Dan- Looks like you started the thread. What's the long run update?
__________________
Andy
Early 99 F250 PSD 4x4 CC 6spd ----- CCV Mod, 6637 Filter, DP Tuner Chip, ITP Fuel Sys, Dahl Filter, Cat Delete, BD 4" Cat Back, 203* 230,000+ Miles
  #53 (permalink)
Old 01-07-2009, 11:12 PM
for now.....
Quote:
I concur. It's even smaller than mine and mine is self imposed.
__________________
Mike
  #54 (permalink)
Old 01-07-2009, 11:32 PM
kccatpower's Avatar
kccatpower kccatpower is offline
kccatpower is starting off with a positive reputation.
read through this and not sure but i saw one person running the cat elc which is the same as rotella elc. with elc it is not recommended to run a coolant filter. the coolant filter adds to the sca level which elc does not need, in time if you are running a coolant filter your sca levels will be too high. any time we flush a system and convert it to elc we remove the water filter and base. also cat sells a flush detergent that works really well for flushing. and a side not after filling with elc check your freeze point. most times with straight elc it will only be around -20. cat sells a concentrate elc to add to the regular elc so you can lower your freeze point.
  #55 (permalink)
Old 01-08-2009, 12:46 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
Methinks you need to do a little advance study on coolant filtration systems before espousing "The Company Line" here.
Virtually all of us in this forum that use coolant filters use the ones without the SCA pellets. I can't recall anyone using the two-unit filters. That's what ours WOULD take, two units. I don't think there's a CAT product small enough to use only two units, but I may be wrong. It's happened before.
I have no idea why you would remove the filtration system. Just change to a different filter. Oh, wait, maybe CAT doesn't make available a filter without SCAs. We couldn't use a different brand of filter, now, could we?
I use Baldwin B5134's and still maintain my SCA's manually (with the assistance of Polaris Labs on occasion). I use the BTE formulation instead of the BTA or BTA+.
There are all kinds of filters out there beyond the CAT parts counter.
If you removed a filter from mine without advising me beforehand, you'd be putting it back on, just with a different cartridge. There is no down-side to using a coolant filter with ELC, unless someone at the dealership uses an inappropriate filter cartridge.
You work for Dean or CAT? Freightliner?
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #56 (permalink)
Old 01-08-2009, 08:54 AM
kccatpower's Avatar
good point, forgot to mention if you run a filter make sure if it has or does not have the pellets added, we remove the filter becuase most drivers do not change thier own fluids, if you change your own fluids and are aware of what filter you need then you are ok, if you have some one change them for you double check thier work. not saying what we do is right just trying to throw ideas out and get feedback, knowledge is power.
  #57 (permalink)
Old 02-03-2009, 02:59 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
Quote:
Originally Posted by Kwikkordead View Post
Took the block drains out, opened the radiator drain. Once all the old coolant was caught, I stuck a water hose in the filler, let it run with the engine idling until clear. Drain it all out again, and fill it using distilled water and coolant 50/50.
So just for clarity... Drain coolant from block and rad... leave plugs out of the block, shove garden hose into rad, let truck idle until the stuff coming out is clear, let drain, replace plugs and fill?
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
  #58 (permalink)
Old 02-03-2009, 03:03 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
No... when flushing with the hose, reinstall the plugs, but only to "finger tight". Then you can drain the block again easily once you finish the hose flushing to help ensure you get the most of the "mineral laden" hose water out of the block before doing the distilled water fills/flush.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #59 (permalink)
Old 02-03-2009, 03:06 PM
1999 Ford F-250
I need to search some more on this I suppose...
__________________
Chase
PAA Member #2
  #60 (permalink)
Old 02-03-2009, 03:44 PM
papadelogan's Avatar
papadelogan papadelogan is offline
of Brent's moral decline
papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE.
I didn't use a garden hose, but MANY MANY jugs of distilled water from WalMart. I flushed 5 times and had a trash can FULL of the flushed fluid. Took time, but I knew 100% that I got out everything that I could. Once she's flushed out good, fill with 4 gallons of ELC concentrate, then top off with distilled. That way your 8-gallon cooling system is as close to 50/50 as you can reasonably get. Using the premix will yield you a 75/25 water/coolant mix. Not so good.
__________________
Brendan
1999 F250 CC SB 4x4 7.3 PSD named "Nyx"
BTS VB;6637;A-pillar (pyro, boost, trans temp);XM radio;Alpine CDA-9831 w/RCA inputs;Leveling kit;Adrenaline HPOP;UnderCover tonneau cover;05 headlights
Tags
97 , 99 , changing , coolant , coolent , diesel , elc , f350 , ford , green , heavyduty , package , powerstroke , red , rotella , sca , shell , towing , truck , wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
