Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 11-09-2005, 07:39 AM
Saguaro_7.3's Avatar
Saguaro_7.3 Saguaro_7.3 is offline
Saguaro_7.3 is starting off with a positive reputation.
F6TA-8B274-FA, that's the Ford part #. NAPA can cross reference the number.
__________________
Saguaro_7.3 '97 F-250, XLT, Super Cab, Longbed, 4x4, Automatic, 190,000, 3" after market downpipe, 6637 Napa filter, exhaust brake.
  #32 (permalink)
Old 11-09-2005, 07:48 PM
taylormade99's Avatar
taylormade99 taylormade99 is offline
taylormade99 is starting off with a positive reputation.
Quote:
Originally Posted by 00250diesel
thanks it just looks a little discolored is that normal? im not sure if there are deposits in it but i guess it doesnt hurt to rinse it out. i looked at napa and they had no idea what i was talking about is there anywhere online i can order the coolant from thanks
I didn't have much luck looking in all the usual places. ie Wal-Mart, Napa, etc. for the ELC coolant and I'm not sure about on-line, but eventually I was able to find it through one of our "Bulk" fuel distributors. Where I live we have some "card-lock" fueling distributors and one of them deals in Texaco and Shell products. I went to their main headquarters and found the Rotella ELC coolant there. $9 for 50/50 blend per gallon. If you have something similar in your area, you may check there. You may also check at a diesel/truck repair shop. I know many ORT rigs run the stuff as well as our D.O.T. I hope this helps.
From what I have gathered, it is not a major consumer product and is not stocked at your usual automotive stores, but some are able to get it. In fact, our local Napa said they could order it and have it here in a week, but at $20 per gallon 50/50!!! Needless to say I went searching further and found what I was looking for 1 mile away from my home.
__________________
1999 (early) PSD F250 SC, 4X4, Auto
Sonnax, Coolant Filter, 02 Excursion (7.3 Powerstroke.....is there any other kind of motor?) No mods yet on the EX...coming soon.
  #33 (permalink)
Old 11-09-2005, 08:02 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
talormade,
You did better than I ever did. I went looking for our local Shell distributorship. They have it in stock, too. $22 a gallon for 100 percent, but a six-gallon "case" minimum. No exceptions.
I'm not ready to change mine right now, as I'm experimenting with extending the life of the additive chemistry of my conventional coolant (with the assistance of laboratory analysis), but when I DO go to an extended-life coolant, it'll be the Shell Rotella ELC.
Wish I could get my hands on a Shell "conversion kit" that they sell to the smaller OTR fleets. With an additive package, it "converts" a well-balanced conventional ethylene glycol coolant to ELC. Dip your existing with a test strip. If it passes, dump in the additive. Run it a few miles to mix it up. Pull a sample to send off to Shell for analysis to insure it "made it". Get results and run it 300,000 miles. Simple!
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #34 (permalink)
Old 11-09-2005, 09:05 PM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
Wowzers!
I didn't realize that it was so expensive everywhere else!
Man I only paid $11 a gallon at a Napa store in Rapid City SD.
Should have bought a gallon or two more!
__________________
'01 F150 5.4L 4x4
  #35 (permalink)
Old 11-10-2005, 11:16 AM
89LX306 89LX306 is offline
89LX306 is starting off with a positive reputation.
I'm with superrangerman...I paid $11 a gallon at my local Pep Boys. They keep the stuff in stock.
  #36 (permalink)
Old 11-10-2005, 01:24 PM
convincor convincor is offline
convincor is starting off with a positive reputation.
Picked mine up today from a local distributor. Couldn't find a retailer that had it.
50/50 $9.32 per gal. Buy the case only.
__________________
68 SWB Custom Cab
FFR Cobra, FE 4spd.
99 SuperDuty Diesel, chipped+
79/80 Ford LGT165 & 145
  #37 (permalink)
Old 11-11-2005, 10:52 PM
01stroker's Avatar
01stroker 01stroker is offline
01stroker is starting off with a positive reputation.
Quote:
Originally Posted by twags6
Does anybody know the napa part number for the upper radiator hose that doesnt go through the fan belt? I looked on their site, but both said they go through and not around....?
I believe the part # is 9066. Tell them you want the one for the dual alternator set up. I got mine at Autozone. Most of the parts places have them.
__________________
01 F-250 Super Duty SB PSD, auto, 3.73 gears. All stock except SCMT tow safe, Ford severe duty AIS, Shortened filler vent pipe, CCV mod, Fuel tank pickup and pre-pump mods. Running on Homebrew Biodiesel.
  #38 (permalink)
Old 11-11-2005, 11:34 PM
underp2 underp2 is offline
underp2 is starting off with a positive reputation.
Quote:
Originally Posted by Kwikkordead
The coolant return flange is leaking a good one on my truck. I ordered some Shell Rotella ELC coolant to fill it back up. That doesn't need the additive like the green stuff does it?
kwik-
Not sure if you have been following my post on thermostats/coolant filters/leaks/etc? Do you have any pics of the leaky gasket that was the culprit? or could you point me in the right direction? is it right at the lower radiator hose, or is it part of the water pump?
I initially had some leaking at the thermostat housing, but that seems to have gone away and it is now leaking from somewhere lower (i think). The weird thing is that it only happens when I have the bypass to the coolant filter open. not as easy to work on things since i have moved-i miss my old garage. Thanks.
__________________
2000 F-250 XLT 4X2, XLT upgrade pkg, PSD, 6 speed, 203* t-stat, Draw-tite gooseneck hitch, Ranch hand grill guard, prodigy brake controller, DIY exhaust brake
  #39 (permalink)
Old 11-12-2005, 10:53 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
I don't have any pictures, but it's the only flange on the bottom hose of the water pump. It comes out on the driver's side, goes through a two bolt flange, and elbows straight down to the bottom radiator hose. The two bolt flange is the one that was leaking. It's sealed up by a rediculuously skinny o-ring. I know for a fact that it is going to leak again long before this ELC coolant is worn out.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #40 (permalink)
Old 11-13-2005, 04:02 PM
where did you get the replacement 'ridiculously small o-ring'? Do you happen to know the p/n? I will probably do that & replace the lower radiator hose at the same time - already did the upper when I installed the coolant filter.
__________________
  #41 (permalink)
Old 11-13-2005, 05:26 PM
Jesus spoke a lot
1999 Ford F-550
I called Ford and they delivered it to my shop. I don't remember the part number. I just gave a description of it's location and function and they said: "Oh, that one, we have it." Yeah it was expensive at $5.++ for a stinkin' o-ring, but the shipping from an online source would have quickly overshadowed any savings.
__________________
Dan
God and Dog
  #42 (permalink)
Old 11-13-2005, 05:31 PM
Ford dealer is right next door to me. that cuts down on shipping costs.
__________________
  #43 (permalink)
Old 11-14-2005, 09:17 PM
Anyone using the Evans NPG+ from dieselsite? What's the difference between that & the other ELC's?
__________________
  #44 (permalink)
Old 03-07-2006, 07:19 PM
aklim's Avatar
aklim aklim is offline
aklim has a good reputation on FTE. aklim has a good reputation on FTE.
Quote:
Motorcraft is KM-4351 or F81Z-8260-CA. I am reading this off the label
__________________
01 Excursion. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BDP Stage II AC injectors. Bilstein Shocks with U code front and A code Rear. 203* thermostat and billet housing
  #45 (permalink)
Old 03-07-2006, 07:24 PM
Muktown Muktown is offline
Muktown is starting off with a positive reputation.
the wal-mart by me just started carrying the cat elc for $9 a gallon but the more i read about it the more im not sure if i will do harm by changing out the green stuff. has anyone had any bad experiences with the elc?
__________________
2000 F-250 Powerstroke Crew Cab Off-Road Hypermax 90hp. Chip Auto Meter Guages. Kwik Filter. Tru-Cool Max Trans Cooler. MBRP 4 inch ss exhaust 215,000 miles and counting
Tags
97 , 99 , changing , coolant , coolent , diesel , elc , f350 , ford , green , heavyduty , package , powerstroke , red , rotella , sca , shell , towing , truck , wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
