Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-03-2005, 11:27 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Quote:
Originally Posted by 01stroker
Hope it don't turn out like mine, had to rebuild it. Seal was leaking.
I completed the repair today. Simple job of two bolts and one o-ring. After that I completly flushed out the cooling system and filled it back up with Shell Rotella ELC.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #17 (permalink)
Old 11-04-2005, 07:50 PM
01stroker's Avatar
01stroker 01stroker is offline
01stroker is starting off with a positive reputation.
How did you flush yours out? Where do you get the Rotella and what does it run on average a gallon?
Thanks Kwik
__________________
01 F-250 Super Duty SB PSD, auto, 3.73 gears. All stock except SCMT tow safe, Ford severe duty AIS, Shortened filler vent pipe, CCV mod, Fuel tank pickup and pre-pump mods. Running on Homebrew Biodiesel.
  #18 (permalink)
Old 11-04-2005, 08:55 PM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
im running the CAT ELC in all my trucks. i think its actually the same as the shell ELC too love the stuff i got the premixed cause i knew that way i would get the perfect di water with it.
__________________
97 F250HD 4x4 supercab 5sp 270k mi
4 link on air front and rear
2000 F350 CC 4x4 (wifes)
RIP CHRIS. 03/09/05
  #19 (permalink)
Old 11-05-2005, 01:20 AM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
Quote:
Actually it is the exact same stuff.
01Stroker:
When I bought my ELC I got it at the local Napa for right around $11 a gallon.
If you can't find it there, the OTR truck shops would be another good place to look.
You simply just flush out the system just like any old radiator system, but you do need to take care and make sure that all of the old stuff is fully removed. There's a nice tech article written up in the tech article section on this very universal proceedure.
__________________
'01 F150 5.4L 4x4
  #20 (permalink)
Old 11-06-2005, 08:40 PM
Jesus spoke a lot
1999 Ford F-550
Thanks Kwik
Took the block drains out, opened the radiator drain. Once all the old coolant was caught, I stuck a water hose in the filler, let it run with the engine idling until clear. Drain it all out again, and fill it using distilled water and coolant 50/50.
__________________
Dan
God and Dog
  #21 (permalink)
Old 11-07-2005, 12:56 PM
89LX306 89LX306 is offline
89LX306 is starting off with a positive reputation.
Quote:
I did the same thing...except I had to remove my degas bottle to clean out the mineral deposits that were in there. You may want to take a look at yours too.
  #22 (permalink)
Old 11-07-2005, 01:03 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
LX,
What did you use to clean it out? An acid of some sort?
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #23 (permalink)
Old 11-07-2005, 01:09 PM
westladog westladog is offline
westladog is starting off with a positive reputation.
where is the block drain located....sorry for the dumb question...
  #24 (permalink)
Old 11-07-2005, 01:16 PM
2000 Ford F-350
Dog,
Not a dumb question at all! Remember, we're all in this adventure together. There was a time that I didn't know the answer, either.
Crawl under your truck and look for the oil filter. To the rear of the aluminum filter adapter there are two plugs on the side of the block. The one closest to the adapter and closest to the pan rail is the crankcase inspection plug. That's not the one you want.
Now, a couple of inches farther up and back, there is another plug. It has a 1/4" square recess (on mine). Don't take it out until it's time to get wet! ;-)))
There's a corresponding one on the other side of the block which is a little harder to get to, but possible. It will look the same.
Pop
__________________
Email SpringerPop
  #25 (permalink)
Old 11-08-2005, 10:35 AM
Quote:
Originally Posted by SpringerPop
LX,
Pop
Acutally it came off easily with the water hose. I just put a spray head on the hose and it blasted it right off. It was mainly built up on leading edges of bends and such of the Degas bottle, so it came off easy.
  #26 (permalink)
Old 11-08-2005, 10:22 PM
00250diesel 00250diesel is offline
00250diesel is starting off with a positive reputation.
whats the degas bottle and where is it? do i have to clean it out to change the coolant and where did you all get the rotella coolant because ive been looking all over and cant find it anywhere
thanks for the help
  #27 (permalink)
Old 11-08-2005, 10:34 PM
01stroker's Avatar
Quote:
thanks for the help
The degas bottle is the one you pour your coolant and water into. I believe some are getting it from NAPA. Unless it has buildup in it just rinsing it out should be OK when you change.
__________________
  #28 (permalink)
Old 11-08-2005, 10:40 PM
thanks it just looks a little discolored is that normal? im not sure if there are deposits in it but i guess it doesnt hurt to rinse it out. i looked at napa and they had no idea what i was talking about is there anywhere online i can order the coolant from thanks
  #29 (permalink)
Old 11-08-2005, 10:48 PM
01stroker's Avatar
The discoloration is normal. I don't know a bout ordering online. I'm sure there is somwhere online that sells it. Maybe someone else can help.
__________________
  #30 (permalink)
Old 11-09-2005, 12:09 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a good reputation on FTE. twags6 has a good reputation on FTE.
Does anybody know the napa part number for the upper radiator hose that doesnt go through the fan belt? I looked on their site, but both said they go through and not around....?
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 149k
PAA Member #7
Tags
97 , 99 , changing , coolant , coolent , diesel , elc , f350 , ford , green , heavyduty , package , powerstroke , red , rotella , sca , shell , towing , truck , wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
