97 F250 Dies while Coasting
Now that I have a little bit more time, I'll try to do a more technical explanation of why I think it might it still might be the the CPS.
Decelleration is one of the lowest fuel demand times for the engine. In fact as Springerpop stated, depending on RPMs or MPHs, the engine may defuel and shut the injectors off (go "quiet") until a certain lower RPM level is reached or the accellerator pedal is pushed / brakes tapped. The PCM(Powertrain Control Module / engine computer) determines RPMs from the CPS. The CPS is "reading" 15* timing points off the camshaft. If the PCM doesn't get those CPS signals it shuts off because it doesn't know where the mechcanical stuff is, i.e. where the cyclinders are in their travels, whether the valves are opened or closed, when to fire the injectors, etc. It shuts the engine off to protect itself from doing something at the wrong time and damaging the engine. If the PCM doesn't get those CPS signals on decelleration, it doesn't know what the RPMs are and when to pick up the idle (start injecting fuel again) so it shuts the engine off. It could be other stuff but I would think there would be other symptoms, i.e. rough idle, poor accelleration. My beer is still on the CPS.
As an aside, I met a guy camping that hadn't changed his fuel filter on his '96 PSD in 44K. (Not recommended) He thought they were like gas fuel filters (his first diesel). He said he never had any problems. I helped him change it. You would'nt believe how black it was.
James.
Under the plastic "Powerstroke" engine you will find a round cannister looking deal...that's the filter.
Locate the yellow handle of the drain valve and open it. Once the filter drains remove the cap turning it counterclockwise, a large pair of slip joint pliers or a oil filter strap works well for this. Remove the old filter and o-rings. Install the new filter and o-rings. Close the filter drain and fill the bowl with diesel fuel or diesel kleen. Re-install the lid and crank it up.
Doesn't take more than 10 minutes and you don't have to lay on your back with gas dripping in your face.
Thanks for all the help. I'm pretty sure it was dirty oil that caused the stalling when decelerating. After the oil change last weekend it died on me once. I usually change the oil at 3500-4000 miles, but I let it go twice that long this time. I'll have to get that filter done this weekend, see how dirty that thing is...
"Lastminute here" I was having that problem and getting worse. the only codes were for exhaust backpressure sensor problems and that did not fix it. turned out to be an oil change. (the oil has an anti foaming agent in it so that it can maintain high pressure on top of the injectors. the agent dies with age. cured my trouble.)( I bought my truck with the problem alredy existing so don't know how old the oil was)
Originally Posted by surfnturf
Well, after changing oil and fuel filter, the truck still dies. Completely shutting off mostly, but not only when decelerating. About the CPS, is that a dealer service item, or can a fairly competent do-it-yourselfer deal with it, and what is involved?
Thanks, James
Thanks, James
http://community.webshots.com/photo/...4042038YpzSoJ#
http://community.webshots.com/photo/...84046575HPSSqb
Don't worry about removing the belt, you can reach the sensor from underneath the truck and remove it with the belt in place. Takes about 10-15 minutes.
#28
Thanks, James
Thanks, James
I've found the coolest picture on line I've seen for the CPS location and what it does. It's a cut away, so you'll not see the internal timing wheel the CPS ia "reading" but it's a great picture.
http://community.webshots.com/photo/...45694045wmgDtW
#29
