vibration
vibration
I,ve got a 74 f100, driving along at highway speed, all of a sudden it will start to vibrate badly. It will shake the steering-wheel out of your hand. You can slow way down and it will stop, then you can regain highway-speed and it may not do it again for a couple of days. It almost seems like it will hit a little bump before it starts the vibration. My brother has a late 80s ford truck and it has started doing the same thing as mine. We,ve rotated tires and checked suspenion, checked brakes. Is this a common problem with these trucks? We haven,t found the problem yet. thanks
vibration
Oily,
There is a possibility of mutiple problems here. My guess is you need shocks. An under damped vehicle can go nuts on you once a problem is set loose. "Loose" is the key word here. You've got to inspect the front end suspension:
1.Front end king pin bushings.
2.I-Beam bushings.Pilot arm bushings.
3. Steering gear box.
4. Tie rod ends
5. Pitman arm
6. Shock absorbers
7. Front wheel bearings.
I will assume that the tires are fine.
The first two are most likely to hide until you hit a bump.
You must have play in something for the front end to shake. Find what's loose and your set.
My Way is the Highway,
KingFisher
4. Tie rod ends
5. Pitman arm
6. Shock absorbers
KingFisher
