K&N cold air kit
Old 10-31-2005, 01:19 PM
Reave1's Avatar
Reave1
Reave1 is offline
K&N cold air kit
Just recently installed a K&N FIPK on my 5.4 3v and I am experincing much louder engine noise when getting on it. Also when it is climbing through second gear I hear a light pinging noise from the valves. Is this normal for this application? Should I use a higher octane gas? If anyone can help let me know, becasue I don't want anything going wrong to my baby.
Old 10-31-2005, 07:15 PM
Flash's Avatar
Flash
Flash is offline
If you want the best for your baby, put the stock system back on the engine. The K&N allows far too much debris to enter the engine and there have been problems with the oil migrating to the electronics.
Old 10-31-2005, 07:20 PM
2Fords1Jeep's Avatar
2Fords1Jeep
2Fords1Jeep is offline
I'll make the popcorn.
Old 10-31-2005, 07:54 PM
Flash's Avatar
Flash
Flash is offline
You make the popcorn and I'll get the Crown Royal. No sense doing this sober. Here is some info for ya ponder:
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Note, the info and test are on a GM Diesel which far exceeds the air requirements of a gas engine.
Have fun!!!!
Old 10-31-2005, 10:39 PM
ReForder's Avatar
ReForder
ReForder is offline
Flash, i have one issue with that study. The A/C Delco results. I've seen reviews of oil filters performed by this group as well, in the past off of a volvo site, and guess what. The A/C Delco oil filter also outperformed all other filters in that test, including K&N, Mobil1, & Mann (the "premiere" european filters). I find it very hard to believe that A/C Delco makes the best products with regards to both air and oil filters. And yes, I am skeptical of these types of "studies", being that I have some experience with research, albiet healthcare/biotech sector. This study needs to be compared to a few other studies before results can be taken as gospel. Just my 2 cents.
Old 11-01-2005, 01:02 PM
Imback123's Avatar
Imback123
Imback123 is offline
I had the same problem with my K&N FIPK. The nosie part anyways. I had it on for a week and hated it. Now its sitting in the garage back in the box. Does the airraid make the same nosie?
Old 11-01-2005, 01:22 PM
JS1600's Avatar
JS1600
JS1600 is offline
I just took my Airaid off because of the same problem. Called Airaid and they said some F150 have it worse than others. I did not have any pinging.
__________________
2005 F150 Lariat Screw 4X4
Borla Cat back SIDO
Old 11-01-2005, 03:25 PM
Reave1's Avatar
Reave1
Reave1 is offline
Well thanks for all your feedback, I removed it today and shipped it back to Summit racing for a full refund! K&N stands behind their product so much that they are giving me my money back.
Old 11-01-2005, 04:07 PM
Imback123's Avatar
Imback123
I wish I would have sent mine back.
Old 11-01-2005, 10:17 PM
ReForder's Avatar
ReForder
ReForder is offline
Are you guys talking about the engine noise as opposed to the pinging? All you're hearing is the throttle body opening, more of a throaty roar of the open cone filter as opposed to the silenced, baffled sealed sound of the stock assembly. It's supposed to sound meaner. The pinging issue is a different story, sounds almost as if your distributorless ignition system advanced the "timing" somehow, perhaps due to increased CFM and colder air from the open filter. Now that may be a good reason to return an upgrade.
