Axle Code "35" = ? - Ford Truck Enthusiasts Forums
Axle Code "35" = ?
Old 10-31-2005, 10:31 AM
go2toa go2toa is offline
go2toa is starting off with a positive reputation.
Axle Code "35" = ?
What does axle code 35 =? This is on the label in the door jam.
Old 10-31-2005, 10:53 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
35= 4.10:1 6250 lb Ford
Old 10-31-2005, 11:20 AM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
It also means you have an open differential, and I believe it refers only to the 10.25" Ford-Sterling semi-float axle.
Jason
Old 10-31-2005, 11:38 AM
subford's Avatar
What I gave was for your 1993, I see now you also have a 2006.
What truck were you asking about?
Old 10-31-2005, 02:10 PM
Its a 1993. Its looks like it could be a full floating axle. Are you sure this coundt be a Dana rear? I think semi-float were just on the F250
Old 10-31-2005, 02:23 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
subford, that is a glich in the fte system.
when people sign up no matter what year they put down it inserts 2006.
you can change it after if you notice it.
alas, it is not a perfect world.
Old 10-31-2005, 08:54 PM
subford's Avatar
Quote:
For any more information you will have to give us the information from the tag that is under the bolt on the rear end. Need both lines.
Old 11-01-2005, 12:22 PM
Upside down but appears to be:
S129G
10 10 2 3E14
Old 11-01-2005, 06:30 PM
Geneoh Geneoh is offline
Geneoh is starting off with a positive reputation.
My 94 F250 has code 35
I do know it is a Sterling 10.25 full float with 4.10 gears open diff.
Old 11-01-2005, 06:41 PM
Did I say "semi-float"? I meant full-float...I knew that. That's why the hubs stick out 6 miles on each side...
Jason
Old 11-02-2005, 01:41 AM
BucksTrucks's Avatar
BucksTrucks BucksTrucks is offline
BucksTrucks is starting off with a positive reputation.
How about H5N? Its spining near 3k RPM at 70mph, with 31x10.5" tires and a M5OD. I know its got that trac loc that dont work much when needed.
Old 11-23-2005, 11:01 AM
Anybody ever have an axle make a strange ticking noise? What is it? It sounds like paper or plastic wacking something as the driveshaft spins. When I put it up on jacks, I carefully looked under there with the motor running in 1st. Sound pretty much went away, but putting the weight on it, the sound came back.
I pulled the rear brake drums and for sure it's not there. It sounds like its at or near the input pinion on the diff (where the plastic is). The plastic "bezel" doesn't appear to be moving at all.
Old 11-23-2005, 02:22 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
It sounds like a bearing. You may have some bearings going bad somewhere inside. Does the pinion move up & down at all when you try to wiggle it? The pinion nut also has a habit of backing off, but that happens more frequently on the 8.8" axle, not the 10.25" that you have.
BTW, your axle is definitely the sterling 10.25, and not a Dana. Whether it's a full float or a semi float depends on whether the hubs stick out through the center of the wheel or not.
Old 11-23-2005, 03:50 PM
I've had this truck for almost 2 yrs. Two days ago, I had a shop replace the differential fluid for the first time in my ownership. Could that be related...? Maybe they just used whatever was on the shelf.
Old 11-23-2005, 05:43 PM
1st thing I'd do is check the gear oil level.
Does it make the noise when turning?
OTC 6695 Axle seal install tool 98-2004 zhigaag Ford Truck Parts for Sale 7 12-21-2015 10:52 PM
axle codes shryock10 1987 - 1996 F150 & Larger F-Series Trucks 4 12-02-2014 08:29 PM
axle and spring codes dakota joe Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 08-31-2005 11:04 AM
1992 Bronco axle code "H9" what is it? biederboat 1978 - 1996 Big Bronco 8 12-11-2004 09:27 AM
1996 F250 4WD Axle Code "C5" ? GregCS 1987 - 1996 F150 & Larger F-Series Trucks 4 03-01-2000 11:27 PM
Tags
1989, 35, 94, 95, axle, code, dana, f250, f350, ford, s129c, s129g, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
