unusual Clunk...
unusual Clunk...
ok. i have a 03 XL 4.2L f-150 with about 25k miles. i bought the truck with 20k miles and have noticed this problem from day one. when i come to a stop, usually after traveling over 35mph(in overdrive) i noticed a clunk when i am about to stop(under 5mph). it is usually more violent when the distance of the stop is shorter.
after i have come to a complete stop, a jitter occures when the break pressure is released.
feels like a transmission problem
You might have a case of the common slip yoke binding disease.
The driveshaft slip yoke binds up on the splines of the output shaft of the transmission.
To see if that's the case you can remove the rear driveshaft and grease the splines in the slip yoke. Ford makes special Teflon grease for doing this but you can use any good quality grease to try it and see if that's the problem.
