Hole in cylinder head - ouch! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-29-2005, 07:16 PM
rocketman442's Avatar
rocketman442 rocketman442 is offline
rocketman442 is starting off with a positive reputation.
I have a '99 F-250 Super Duty (5.4L) with 263,000 miles on it. It developed a pinhole in the LS cylinder head right below the thermostat housing, causing a coolant leak. After sticking it with a screwdriver, I ended up with a 1/2" hole!! Has anyone ever encountered this? I can't even drill & tap it as it is near the top of the head where there is a bend in the casting. I really don't want to pull the head off - is there some "super epoxy that will stand up to the coolant temperature/pressure? Thanks.
Old 10-29-2005, 07:55 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Maybe get someone to Tig weld a patch on it.
I would say it was corrosion from not changing coolant ???????????
A 1/2 inch hole is to big for jb -weld
Don't forget if you have someone weld it to disconnect the battery and isolate the pcm grounds also or you will blow up the pcm.
Rich
Old 10-29-2005, 08:22 PM
bigsbetter bigsbetter is offline
bigsbetter is starting off with a positive reputation.
I'll have to agree with Fortyfords. It sounds like your coolant became acidic.
Old 11-02-2005, 11:07 PM
OK - I went the JB Weld route. I hammered out a 1/16" piece of aluminum to fit the corners and to cover the hole by 1/2" on all sides. I sanded the area and wiped it down with acetone, then JB'd the whole thing. If this doesn't work, then I might use an expanding rubber plug. I'm afraid of what the heat might do to the head if I have it tig'd, given the thin wall thickness. I'll know by tomorrow!!
Old 11-03-2005, 07:16 AM
dew487 dew487 is offline
dew487 is starting off with a positive reputation.
For what it's worth, I have had good luck using JB weld on my 1941 Ford 9N tractor. My cylinder block developed a 1/2" crack at the water jacket. I ground v-groove at the crack and applied JB weld. It's held up for 3 years now... Hope it works for you.
Old 11-06-2005, 09:24 PM
All is well with the repair. I have about 50 miles on it with no signs of leakage. While I had the opportunity, I replaced the thermostat (original!!), o-ring, tensioner bearing (got it at Grainger for $6.76), belt & coolant. My owner's manual says "if it has orange coolant, use the long-life stuff; if it has green coolant, use the regular stuff" (not verbatim). I asked my local dealer and they said the same thing. GAR! Being that my coolant was orangish-green, I flushed the whole thing and put in the green stuff. I'm keeping my fingers crossed!!
Old 11-06-2005, 11:09 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I heard about this as a known issue... coolant flow past that point erodes the metal, and it leaks.
I have NO idea if there is a fix or updated head, I only know what I've read on this site
art k.
Old 11-18-2005, 04:11 PM
texcan's Avatar
texcan texcan is offline
texcan is starting off with a positive reputation.
How is your repair holding up? Interested in knowing!
Old 11-18-2005, 07:51 PM
bear1911 bear1911 is offline
bear1911 is starting off with a positive reputation.
I had this happen on my 99 V10. Ford repaired using a sleeve and epoxy in the coolent passage. There were casting issues on the heads.
Old 11-18-2005, 08:24 PM
Quote:
So far, so good! I put around 300 miles on it with some heavy hauling and no leaks!! I went bananas preparing the surface, which I guess paid off. I have some pictures of it and I'll have them up here as soon as I remember how to do it! A while ago, I repaired a broken 442 emblem stud with JB Weld (then threaded it with the speed nut!) and have sworn by it ever since. It has a working temperature of 600 degrees F, so 200 degrees F is a walk in the park.
Bear1911 - Is the sleeve to which you are referring a V10-specific item? Would one be able to get this right from Ford parts?
Brad
Old 11-18-2005, 08:34 PM
Krewat's Avatar
You can never prepare the surface too much - unless, of course, you break through to the other side
Old 11-18-2005, 10:37 PM
Brad
I don't know if it is specific to the V10, the shop manager said this was a known issue with the heads, so my guess is that it could have affected the v8 also. It was warranty work. I do not have a part number.
Old 11-20-2005, 08:30 PM
Here are the pics. Unfortunately, I took the picture of the actual hole with my phone.
http://img26.imageshack.us/img26/5316/dsc015443vn.jpg
http://img504.imageshack.us/img504/1544/dsc015461kq.jpg
http://img469.imageshack.us/img469/4538/dsc014091rg.jpg
http://img469.imageshack.us/img469/259/dsc013951hb.jpg
Images changed to links (it's a little nicer for the dial-up users. -Beast12
Old 10-05-2008, 04:13 PM
Hole in cylinder head update
Well, it's been almost 3 years and 13,000 miles since fixing my cylinder head with J-B Weld and it's holding up great! This stuff is unbelievable!!
Old 10-05-2008, 04:36 PM
tac53parsons tac53parsons is offline
tac53parsons is starting off with a positive reputation.
Thats crazy!!! My truck has 130,000 on it. I hope mine lasts as long as yours. What kind of repairs have you had to do? Transmission?
Coolant in cylinder.??? lmassmann Modular V10 (6.8l) 9 06-19-2014 08:17 AM
Head Gasket Preperation Help!! Bubba Jones Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 16 02-15-2014 10:45 PM
223 with busted cylinder pholmes350 Ford Inline Six, 200, 250, 4.9L / 300 2 12-30-2013 09:06 PM
99 F250 Super Duty 6.8L V10 Coolant System Problems FireFighter12105 1999 to 2016 Super Duty 5 02-15-2010 07:17 AM
302 coolant leak operator exmark Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 03-04-2008 10:40 AM
Tags
broken, corners, cylinder, epoxy, ford, head, heads, hole, holes, jb, leak, patch, picture, pinhole, repair, v10, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
