Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #121 (permalink)
Old 11-25-2007, 09:44 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
I still got noticeable smoke with mine on a cold start. Always starts up though. Everything is new except for the VC gaskets. So if your replacing the gp's pry be a good idea to do the vc gaskets too.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #122 (permalink)
Old 11-27-2007, 01:38 PM
FARM69's Avatar
I'm starting to believe that mine is over smoking at idle. I've tested the gp's and they all seem to be fine (they should be, I just replaced them a month or two ago along with the gpr). My question is would I have more smoke with the 10 k and big injectors/nozzles? My question being that the increased oil pressure is putting more fuel out there than the computer knows, hence making it smoke. Doesn't smoke a lick once I get the egts up to 250-300 or so.
What about the fuel bowl heater?
It's also seems like it takes more cranks to start up aswell. Warm/cold is doesn't matter. Hmm.. maybe I'm just starting to imagine things now.
I'm gonna try and post of video of a cold startup.
__________________
  #123 (permalink)
Old 11-30-2007, 05:13 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
TTT, this needs to be a stickie.
__________________
Horsepower = How fast you hit the wall.
Torque = How far you take the wall with you.
They say if you play a Microsoft CD backwards you hear scary messages.
Even scarier......if you play it forwards it installs Windows
  #124 (permalink)
Old 12-08-2007, 07:03 PM
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
i noticed my truck white smoked for a while idleing this morning is there anything else that could cause that but glow plugs
  #125 (permalink)
Old 12-08-2007, 08:47 PM
scatgo's Avatar
scatgo scatgo is offline
scatgo is gaining momentum as a positive member of FTE.
dddddddddddddddddddddd
__________________
1994 F350 CC Dually
7.3 DI TURBO DIESEL
5 SPEED
HPX, FPR shimmed, Edge
Intake, Downpipe, Cat delet
  #126 (permalink)
Old 12-22-2007, 04:36 PM
Tim Young Tim Young is offline
Tim Young is starting off with a positive reputation.
Wow what a thread!! I have learned alot about the GPR and Glow Plugs and it seems as though I have glow plugs that are not working. Sense I was in the driveway in a snow storm, I could only test the rear two on passenger side and front two on drivers side without some disassembly. I used the test light method and it appears there is no continuity. Has any one used the AC Delco brand of glow plugs? $6.95 each at the local parts store.
Tim in Chelan
__________________
1997 F350 Crew Cab, 7.3L Power Stroke, The Luxury Liner
1968 F250 Camper Special, 390, The Wife's Truck
1969 Bronco, Work in progress
2004 Eddie Bauer Explorer,
  #127 (permalink)
Old 12-22-2007, 10:01 PM
Quote:
Originally Posted by bodabdan
Checking glow plugs with test light-
For anyone not fluent in multimeters, connect the ground clip of a test light to a battery positive.
touch the pointed end to a glow plug tip or the wire that goes to the tip.
Light comes on-good plug.
No light- bad plug
Well after rereading this post I may not have did it right. I have two electric plugs on each side one near the back and one near the front on each side. There were not eight pins in the plugs either I think there were only 5 pins and I touched the two outer most pins. I am fluent with a multimeter so when I get a chance I will measure all of the pins and see what I have, at least from the back plug on the passenger side for starters.
Tim
__________________
  #128 (permalink)
Old 12-26-2007, 04:49 PM
'00RedSD's Avatar
'00RedSD '00RedSD is offline
'00RedSD is starting off with a positive reputation.
2000 7.3 with k&n kit, hypertech programmer set on #2. Hard to start in the cold, 45 or lower. Smokes when trying to start and runs ruff for a few seconds after start. Batteries are good, had them tested, new bat conectors.. Changed the GPR.
I ohmed the pass side and they all read 1.4 or 1.5.
The driver's side all read 0.0, I doubled checked the common and tried again and the same 0.0.
Any suggestions?
  #129 (permalink)
Old 12-31-2007, 11:40 AM
realpower realpower is offline
realpower is starting off with a positive reputation.
Hi there!
New to the forum, read all of this thread...
I have a 2000 that is starting to get hard to start in the morning. It always starts, but recently (as its been colder I guess?) It has been starting and romping (romp romp romp romp) If I hit the gas it smoothes it out but doesnt rev past 1200 or so for a few seconds, and it is slow as hell for a mile or so. It pushes a little white smoke, not excessive. Is this low oil pressure in the HPOP circut, or glow plug related? any help would be appreciated!
  #130 (permalink)
Old 01-02-2008, 07:39 PM
300sixpack's Avatar
300sixpack 300sixpack is offline
300sixpack is starting off with a positive reputation.
Great thread! However, I have a strange problem not related to GP's or the GP Relay, but maybe ICP or CPS.
I have a stock 97 PSD. Won't start worth a crap. Been going on for about a month now. When warmed up using a block heater, it will turn over fine and fire off, then quit. Then it acts like it isn't getting fuel (by the sound of it, and it doesn't smoke). If I wait for a while, cycling the GP's, it will eventually start, but when I got back from the holidays and it took me 2 HOURS of worth of cranking in the airport parking lot for the damn thing to start (Thank God for high Cold Cranking Amps batteries ).
There is also one really strange thing that has happened 3 times, all of which after it was plugged in for more than an hour, and after 15-30 minutes worth of cycling the GP's and trying to start every 3-5 minutes or so. The first time it happened, it sounded like pressure being relieved somewhere, then a "thunk" sound. The next two times, it was a definate clunk, like something opening or closing. Immediatley after (in each instance), the engine fired right up, first crank.
I will try the ICP test, as I suspect that might be the problem, but a trusted source told me to also check the Cam Positon Sensor. Any other ideas?
EDIT:
Continutiy of all GP's tested fine, as did the GPR.
Also, my tach has never registered any RPM's while cranking since I have owned it, therefore I don't know if I am getting above 200 RPM's while starting.
I'm gonna post this in a new thread, as my problem sounds fairly unique.
  #131 (permalink)
Old 01-03-2008, 02:05 PM
1969fordguy 1969fordguy is offline
1969fordguy is starting off with a positive reputation.
I hate the cold.
My truck won't start. Again. SO I drove my $300 1976 RV to work today. I hate the cold.
So I was rereading this post for my next thing to fix on the $14,000 truck (see how I got to work today, above) and I got to thinking... How long should the GRP-109 last? I put one in two years ago (along with glowplugs).
I'll be checking the resistance of GPs, ICP unplug test, fuse #22, block heater, and recharge my new 1000 cca batteries.
I hate the cold.
__________________
1997 Powerstoke 7.3L Turbo Diesel 4X4
3" to 4" downpipe, 4" stainless exhaust, superchips programmer, boost, pyro, & trans temp gauges, 6637 filter, 203* thermostat
Yes, it does sound good!
TRUCK IS PARKED DUE TO DIESEL PRICES. CURRENT TRANSPORTATION IS A 600CC MOTORCYCLE
  #132 (permalink)
Old 01-04-2008, 10:23 AM
As it turns out, just a bit less than two years is how long a GPR-109 lasts. It still worked, but poorly. So I replaced it. $34 counting tax from NAPA. Starting this morning (17 degrees) there was greatly reduced white smoke after starting during the warm up.
__________________
  #133 (permalink)
Old 01-04-2008, 10:35 AM
IceboxFX's Avatar
IceboxFX IceboxFX is offline
IceboxFX is starting off with a positive reputation.
good to hear it worked out for you. I had to replace my GPR last winter and got it from napa, but they charged me like 50 bucks. guess i should look forward to replacing it again next year :/
__________________
97 F-250 Ex Cab 4x4 7.3 PSD
Truck pics
http://inlinethumb39.webshots.com/34...200x200Q85.jpg
  #134 (permalink)
Old 01-11-2008, 10:42 AM
ToyoDiesel ToyoDiesel is offline
ToyoDiesel is starting off with a positive reputation.
I have had this cold start problem for a couple of weeks, but today the truck will not start on a 50 degree morning!
I changed the GPR and had the batteries checked. The truck turns over and catches but will not start. The tach is moving.
I couldnt find the block heater before but I foud what looks like a 120v plug just below the driver's side battery. Is that it?
  #135 (permalink)
Old 01-11-2008, 11:16 AM
Trakk's Avatar
Trakk Trakk is offline
Trakk is starting off with a positive reputation.
yep. that's it.
Tags
1826703c1 , 2003 , 73 , 73psd , 97 , bad , diesel , ford , glow , gpr , hard , meter , ohm , pics , plug , powerstroke , signs , smoke , start , test , white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
