Can't help you with NAPA but there is only 1 good GP. Motorcraft ZD11 (beru) that I know of. The NAPA here in town is the worst part store...ever. They never have anything in stock, there prices are higher than everyone else...and....and....Ok done ranting.
__________________ Horsepower = How fast you hit the wall. Torque = How far you take the wall with you.
They say if you play a Microsoft CD backwards you hear scary messages.
Even scarier......if you play it forwards it installs Windows
lastnight tried to start my truck and cycled the key on and off severval times it didn't wanna start but did i know i have atleast one bad glow plug and needs replaced i ohmed it out and i'm gonna get a new gpr it can't hurt my question is after the truck started i let it idle for 5 mins before driving it then drove it for 5 miles and it ran like it wasn't firing on all the injectors had what felt like a miss to it once it got warmed up it ran better and had more power... could this be my injector o rings going bad or some other type of injector problem if it i would like to replace all the injectors and glow plugs at the same time.. if it is injectors i'm either going with stage one's or two's what would yall do? thanks
it is a 99 f250 sd crewcab sb 7.3 psd, purchased the truck 1 month ago tomarrow. it did good for the first week i owned it. then i started having problems, so my first thing todo was replace the GPR, unfortunately I didnt read the thread here or do any research, just told em what it fit.. so seventy dollars later, i got a new gpr... i think it was a gpr11. any way that helped a bunch, but now since it colder i have noticed a very poor starting condition, it sounds like it turning over fast enough, but it sounds like only one cylinder is trying to lite per revolution, and smokes bad while cranking, and for a few seconds after i do finally get it started. i have tried alot of different ways of trying to start the truck, right after key on, cycles "x" number of times, 5 max. if i sit there and just crank on it it will start but i REALLY dont like doing that, i know its tearing up the starter... thats why i dont run the truck much right now. my question is do i need to check the sensor for the oil pressure on the rails, or do i just need to plan on doing the gp's? as I am a bit tired right now I am gonna check the ohms on the injector harnesses tommarrow, and also she what the gp's cost at oreillys..
josh
update: just so you guys know I went outside this morning after the truck had sat for about 4 hours in 23 degree weather, and decided to test the voltage at the batteries during crank and the truck started right up.. the key was on for a max of maybe 30 seconds.. when I have left the key on for well over a minute before with all the key cycles and such trying to get it to run.. but as a side note i did not see the voltage go below 10 volts..
arkredneck, your issue sounds normal for a cold powerstroke, even more so if a plug doesnt work at all, remeber that oil has to thin out to fire properly,
it sounds like a glow pug problem, hit autozone, they are 2.99 each
oh, well in that case, your injectors are screwed. garbage, trashed. might i sugest a set of aftermarket stage 1's or stage 2's? they are half the cost of ford stock remans and will be a big improvement in your truck.
i've been looking but the only difference i can tell in stage 1's or 2's is the nozzle and 2's cost a lot more i'm really not wanting to have to get a new hpop to run new injectors or a bigger turbo so i really don't know whats best for me
yup, the main difference is the nozzle is changed in the 2's. i would go with 2's and get a super duty high pressure pump, odds are your stocker is worn as is and if you are going to spend the money on injectors just go with big ones one time, i have heard alot of guys that bought ones say they wish they got 2's and been done with it
Been lurking for awhile and got a lot of good information off this site. Now I am having the cold start issues with my '96 PSD. It starts fine when it is plugged in, but takes awhile if it isn't. It runs smooth when it does start up so I think the GP's are OK, I did the test light on the GPR and it stays on for about a minute and a half. I did get it to fire after cycling the GP's 4 times at about a minute and a half each time. Is this just going to have to be my ritual or should I check something else? Also, I get white smoke coming from under the hood when cranking it over when it is cold, is that normal?
First you can ohm the GP's I believe you have atleast 1 bad GP. I have 1 bad and it does the same thing.
Second, the smoke from under hood is either a leaking exhaust manifold or uppipe. I think I have the same thing because my smoke comes from under the right front wheel.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
