Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 11-24-2006, 11:27 PM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.
the bulbs come out of the back of it. look at your black dash beezel, there is 2 removable strips on each side, pop em out, undo the 8mm (?) screws. pop off the headlight knob, pull beezel away from dash, diconnect wiring harness from back of wts cluster, unscrew and remove the little box. there is 4 bulbs or so in there. replace em.
__________________
05 D-MAX WITH SOME GOODIES
  #62 (permalink)
Old 11-28-2006, 10:50 AM
brokebronco's Avatar
brokebronco brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.
Bump for the sticky
__________________
Chris
84 Bronco 351HO/NP435/208/10.25 Rear/D60 Front
86 F250 351HO/C6/10.25
New rig
96 F350 crewcab 2x4 with the 7.3l
  #63 (permalink)
Old 11-28-2006, 08:31 PM
travisd travisd is offline
travisd is starting off with a positive reputation.
I've got one bad GP, front on the passenger side. I figure if I'm going to fix it, I will do all 4 on that side. Are the valve cover gskts reusable, if not, where's a good place to get them?
  #64 (permalink)
Old 11-28-2006, 08:33 PM
1997F-350's Avatar
Quote:
Originally Posted by brokebronco
Bump for the sticky
it was a sticky last winter in here and the sd forum. then in the spring they pulled it. i had cookie put it back up about 2 months ago but then they made a change to the stickys. oh well.
__________________
  #65 (permalink)
Old 11-28-2006, 08:34 PM
1997F-350's Avatar
Quote:
as long as the connectors for the wiring arent burnt and the sealing surface is good yes they are re useable.
__________________
  #66 (permalink)
Old 12-06-2006, 10:07 PM
I would like to bump this because it is getting cold outside and this thread is full of useful info.
  #67 (permalink)
Old 12-08-2006, 09:23 AM
Trakk's Avatar
Trakk Trakk is offline
Trakk is starting off with a positive reputation.
Mine has been starting worse even with the block plugged in. Do you think bridging the terminals on the GPR is the first test I should try?
  #68 (permalink)
Old 12-08-2006, 12:44 PM
1969fordguy 1969fordguy is offline
1969fordguy is starting off with a positive reputation.
The Glow Plug Relay probably needs to be replaced if you haven't done it yet. The jumper test is alright, but replacing a part that is known to go bad is a sound investment.
__________________
1997 Powerstoke 7.3L Turbo Diesel 4X4
3" to 4" downpipe, 4" stainless exhaust, superchips programmer, boost, pyro, & trans temp gauges, 6637 filter, 203* thermostat
Yes, it does sound good!
TRUCK IS PARKED DUE TO DIESEL PRICES. CURRENT TRANSPORTATION IS A 600CC MOTORCYCLE
  #69 (permalink)
Old 12-08-2006, 12:47 PM
Trakk's Avatar
THANKS! Is there a thread that turns that job into a step by step process? I think I'd try to replace it myself if I knew where it was. LOL
  #70 (permalink)
Old 12-08-2006, 12:59 PM
plowhand's Avatar
plowhand plowhand is offline
plowhand has a good reputation on FTE. plowhand has a good reputation on FTE.
GPR relay replacement: Remove engine cover. Right (passenger) side of engine behind HPOP reservoir is the GPR (looks like a starter solenoid. Disconnect BOTH negative battery cables. Disconnect the wires from the terminals on the GPR, remove old GPR from mount. Install new GPR on mount, reconnect the wires to the terminals on the new GPR. Reconnect BOTH negative battery cables. Replace engine cover. Done.
__________________
95 F250, XLT, 2WD, 5 Spd, 4.10 l/s, SuperCab, Longbed. Beans Stage II's, Open air intake, EBPV gutted, SSX, downpipe, CAT gutted, 10K mod, shimmed FPR, GPR control switch, gauges (Pyro, Boost, AMPs, mechanical Oil Pres. & mech. Water Temp.)
02 F150 Super Crew, Lariat (Wife's)
81 Bronco with 460
  #71 (permalink)
Old 12-08-2006, 01:03 PM
Trakk's Avatar
Sounds pretty easy. I'm gonna have a look at it.
  #72 (permalink)
Old 12-08-2006, 05:19 PM
Trakk's Avatar
Got my GPR changed out. We'll see in the morning if that fixes the cold starting issue. Thanks for the help.
  #73 (permalink)
Old 12-08-2006, 06:50 PM
plowhand's Avatar
Anytime, most of the things that need to be fixed are really not that hard, some just take alot of time. Let us know if it helps.
__________________
81 Bronco with 460
  #74 (permalink)
Old 12-09-2006, 08:23 AM
Trakk's Avatar
hey plowhand and helpful others...
It seems like the new GPR may have helped some. I think it's causing the GP's to cycle longer than they were. However, still taking forever to get my engine to fire up. Also--I forgot to mention I've been leaving the block heater plugged in all night long. Shouldn't it be starting easily unless something's wrong with the BH?
Please comment on what might be next to check:
- glow plugs
- oil weight change (still using 15/30)
- coolant/antifreeze reservoir is really low
- battery check (2 new Napa batteries about 8 months ago)
  #75 (permalink)
Old 12-09-2006, 10:56 PM
plowhand's Avatar
To check your block heater: with an ohm meter, make sure you have continuity between the plugs on your block heater, if not, bad block heater, replace it.
To check your glow plugs and/or UVC (Under Valve Cover) wiring: Disconnect your valve cover connectors. There are five pins inside, 1-2-3-4-5. Pins # 1 & # 5 are for the glow plugs. Pin # 3 is common (ground). Ohm from one of the glow plug pins to an engine ground and then to the common pin. Ohms should be 3 - 5 ohms, (7 max). If the engine ground and common pin ohms have a large variance, this could mean that the UVC (Under Valve Cover) wiring has problems.
As for the oil, 15W40 is recommended for normal climates, 10W30 for temperatures below 20 degrees fahranheit.
Low coolant will not effect starting.
If it is spinning over fast, your batteries should be good. But remember "new" does not mean "good". It takes alot of amps "NOT VOLTS" to start our trucks.
__________________
81 Bronco with 460
Tags
1826703c1 , 2003 , 73 , 73psd , 97 , bad , diesel , ford , glow , gpr , hard , meter , ohm , pics , plug , powerstroke , signs , smoke , start , test , white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
