Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 03-04-2006, 12:06 PM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by vastroker1975
when changing the glow plugs, I understand that I have to remove the valve covers. Now I priced out gaskets, and they want 136.00 at autozone for these per side. Has anyone came across this, and have you had to change the gaskets? I have a 96 7.3L PSD.
if nothing is burnt on the electrical connections and they are not messed up they are reusable gaskets.
__________________
05 D-MAX WITH SOME GOODIES
  #47 (permalink)
Old 03-19-2006, 10:49 PM
viperrtblck viperrtblck is offline
viperrtblck is starting off with a positive reputation.
97 hard start white smoke GOOD plugs and GPR
97 with all hypermax stuff...chip turbo cooler injectors pipe etc. STILL has hard start when cold and white smoke puff at startup (then smokes average amount for having injectors) i checked all glowplugs at the harness connector and all had continuity(all also had around 1.7 ohms) and i put a new relay on just to be safe. but STILL the problem persists. if i plug it in, hard start is eliminated but still some white smoke somewhat at startup. what the hell's going on with this truck? possibly fuel pump: engines warm so seals and stuff are expanded and can seal or what not. but when it's cold, their contracted and having difficulty doing their job!? something in fuel pump possibly? i dunno..help me out! maybe this is just how this itruck is?!
  #48 (permalink)
Old 03-20-2006, 01:56 AM
dutchrobert dutchrobert is offline
dutchrobert is starting off with a positive reputation.
Hi Vipertrtbllck that sounds like mine truck i did change one glowplug since the rest seems to be allright, but still diffecult to start in the cold weather and also a lot of white smoke. Someone said to me that it is just unburnt diesel because of bad starting. Got now glue if thats the thing! I drive an standard E350 7.3 L from 95
  #49 (permalink)
Old 10-01-2006, 09:58 AM
73strokin 73strokin is offline
73strokin is starting off with a positive reputation.
Question Glow plug temperature sensor
My '96 Powerstroke doesn't start under about 55 degrees without using ether. So quickly I am going to replace the glow plugs, glow plug relay, and valve cover gaskets, all of which I already purchased. Aside from the wiring harnesses, what other parts are there to this glow plug circuit? My glow plug light will stay on for maybe three seconds when it's 60 or above, and down to 40 degrees it will stay on for about 8 - 10 seconds. I haven't owned it in any colder weather yet. I would think it should be staying on longer than 8 seconds at 40 degrees?
So after looking at a Ford service manual, my question is about a temperature sensor in the engine block or oil pan. I've read that this reads the temperature and sends a signal to tell the relay how long to stay on. Has anybody ever heard of or replaced this part? And would you know if this is a dealer part or if it could be bought at NAPA? Provided I don't want to play around with this, I would rather replace as much of the circuit as possible provided this sensor wasn't a ton of money.
I appreciate any comments!
  #50 (permalink)
Old 11-24-2006, 02:33 PM
1997F-350's Avatar
To The Top!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
__________________
  #51 (permalink)
Old 11-24-2006, 03:07 PM
brokebronco's Avatar
brokebronco brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.
I have the same issues with the cold starting but also have no wait to start light or any other diesel related dash light functioning.
__________________
Chris
84 Bronco 351HO/NP435/208/10.25 Rear/D60 Front
86 F250 351HO/C6/10.25
New rig
96 F350 crewcab 2x4 with the 7.3l
  #52 (permalink)
Old 11-24-2006, 03:29 PM
1997F-350's Avatar
try unplugging your fuel heater wire on the side of your fuel bowl. there is two on the side it is the upper one. then in the under the hood fuse box replace the #22 maxi fuse and give it a try.
__________________
  #53 (permalink)
Old 11-24-2006, 03:49 PM
Unplugged the conector and changed the fuse, still nothing. I just tested the glow plugs and the relay. GPs bad relay seems alright, I have voltage present at the VC harness connector.
The Truck is new to me, got it on Wednesday. 96 F350 crewcab 2x4.
By any Chance are the later model valve cover gaskets able to be used on this truck? I have a set in the shed, I will get the P/N off them and post tonight or tomorrow.
__________________
Chris
New rig
  #54 (permalink)
Old 11-24-2006, 03:53 PM
1997F-350's Avatar
was the fuse blown when you pulled it out?
are you sure you unplugged the correct wire? its kinda hard to get at.
__________________
  #55 (permalink)
Old 11-24-2006, 03:54 PM
1997F-350's Avatar
if you pull the wire and fuse is good and then no lights something else is blown.
the maxi fuse is a big one.
__________________
  #56 (permalink)
Old 11-24-2006, 04:14 PM
There were two connectors. I pulled the top with a square looking end and the fuse wasn't blown.
I just checked for voltage at the connector for the wait to start light assembly. Good there, looks like the light circuit board is bad or something.
__________________
Chris
New rig
  #57 (permalink)
Old 11-24-2006, 04:30 PM
1997F-350's Avatar
will the truck start now?
__________________
  #58 (permalink)
Old 11-24-2006, 05:27 PM
It does start, just not when cold out, I guess the lights are there just to entertain people.
__________________
Chris
New rig
  #59 (permalink)
Old 11-24-2006, 05:35 PM
1997F-350's Avatar
Yup The Lights Are Probably Blown. Those Are An Easy Fix. Ok So Re Attach Your Fuel Heater Cord To The Fuel Bowl Then And Check Out Your Gpr And Glow Plugs With An Ohm Meter.
If You Need It To Start Just Plug It In For About 5 Minutes Or So With The Block Heater.
__________________
  #60 (permalink)
Old 11-24-2006, 08:19 PM
Do you know where/ if the wait to start light assembly is available?
__________________
Chris
New rig
Tags
1826703c1 , 2003 , 73 , 73psd , 97 , bad , diesel , ford , glow , gpr , hard , meter , ohm , pics , plug , powerstroke , signs , smoke , start , test , white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
