Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 12-22-2005, 11:52 AM
PSD97's Avatar
PSD97 PSD97 is offline
PSD97 is starting off with a positive reputation.
Exactly how much (or for how long) smoke is considered "normal" at cold start?. Lets say temp is 40 degrees. Is it actually possible to have none at all? Mine pumps out white for maybe 10 seconds, or about a garageful, after that there is still some brown, not all that visible smoke coming almost indefinitely or until I start driving, when all smoke disappears entirely. It's a -97 PSD w/85000 miles and probably original plugs and all. No other performance problems.
  #32 (permalink)
Old 12-22-2005, 04:19 PM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.
that is fine....
if you wait about 20 seconds after you turn the key you should have almost none....
if you still do you may have a gpr on its way out or 1 or 2 plugs bad...
__________________
05 D-MAX WITH SOME GOODIES
  #33 (permalink)
Old 01-29-2006, 09:38 PM
rascal1 rascal1 is offline
rascal1 is starting off with a positive reputation.
Hi I have a 96 f250 psd and just recently began really hard to start problems. I was at a cold temp and couldn't plug it in and couldn't start it towed it to a plug and it started after 2-3 hours of warming. Then i got it to 50 degree weather and had the same problem. I was previously noticing a ton of white smoke before when starting it cold but now it just cranks. I went out and changed all 8 gp's and the problem is still there. Still won't start when cold. Lastly I hear the initial click when i turn the ignition on see the voltage drop but never hear the second click after it should time out? any ideas?
  #34 (permalink)
Old 01-30-2006, 08:05 PM
ealbertson ealbertson is offline
ealbertson is starting off with a positive reputation.
Sounds like a bad glow plug relay. Look at some of the previous replies in this thread and it will tell you how to test it. My truck did exactly the same thing.
  #35 (permalink)
Old 02-09-2006, 05:24 PM
magnum300 magnum300 is offline
magnum300 is gaining momentum as a positive member of FTE.
I was trying to change mine today but do not have a socket to fit the nuts that attach the gpr to the engine , what size are they?
__________________
2000 7.3L diesel F250 SD Ext cab long box 4x4 auto trans, kwiks 6637 air filter, 5 in exaust, SSX, Mag hytec rear differential cover
  #36 (permalink)
Old 02-15-2006, 10:10 PM
paulsdream paulsdream is offline
paulsdream is starting off with a positive reputation.
i have a 95 f250 diesel that at around 1200-1600 rolls white smoke what im wonderin could this have to do with a junk chip that the previous owner could have installed?
  #37 (permalink)
Old 02-16-2006, 06:17 AM
1997F-350's Avatar
you should make a separate post from this....are you sure its white? be more specific when it does it like cold/hot and everything else you can think of and we will help you.
__________________
  #38 (permalink)
Old 02-16-2006, 06:50 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
...Welcome Paul to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #39 (permalink)
Old 02-16-2006, 07:07 AM
it smokes when its warmed up in the first 2 gears not under load and it blubbers like there is a dead spot in the computer.
  #40 (permalink)
Old 02-23-2006, 02:27 AM
dutchrobert dutchrobert is offline
dutchrobert is starting off with a positive reputation.
yeah mine E350 wouldn't start last week and finally with some help it did, i guess it has something to do with the glowplugs but since it also gave a lot of white smoke during the summer i thought it was normal (bought it last year) but with the cold weather it doesn't sart anymore. since i have two lefties i had to bring it to the workshop will let you know if anything odd was done to it.
  #41 (permalink)
Old 02-23-2006, 11:09 AM
samahi72 samahi72 is offline
samahi72 is starting off with a positive reputation.
Hydro Locking
When I replaced my gp's I made the mistake of allowing some oil from the rail to get inot the cylinders. VERY BAD THING TO DO. Not realizing it, I finished putting everything back together and when I tried to start it, it wouldn't even turn over, it was hydro locked. Fortunately it didn't do any damage. I had to start all over and pull each gp out and clear the cylinders of the oil. So my recommendation is after you pull out the glow plug, just insert a long clear rubber hose into the cylinder and suck on it like a straw or hook it up to a shop vacuum cleaner and make sure there isn't any oil in the cylinder.
We all learn from each others mistakes and hopefully don't repeat them.
__________________
samahi72
  #42 (permalink)
Old 02-23-2006, 08:00 PM
i already did that job and before u start pullin the gps out u use an air chuck to remove any access oil
  #43 (permalink)
Old 03-02-2006, 01:00 PM
Freakazoid!'s Avatar
Freakazoid! Freakazoid! is offline
Freakazoid! is starting off with a positive reputation.
Great thread! I had to replace my glow plug relay this week, and I've got a couple of things out of it:
First, you cannot tell by the in dash voltmeter if the GPR is bad or the glow plugs themselves are bad (if you still have a voltage drop)
Second, the GPR-109 and GPR-110 are almost identical, but at $23, the GPR-109 is cheaper (NAPA), but the manuals said I needed the 110 (for a 1997 model). It took some figuring out, but the 110 is apparently rated for a longer load time than the 109 - this is important for folks like me who live in colder climates and have the relay energized for longer periods of time. Otherwise, they are nearly identical, they exception being how the mounting tabs are rotated.
I was lucky when I replaced my relay. When I was removing the electrical connections, the battery lead came completely out of the old relay. I was pretty happy that I had a "smoking gun" in my hands since it was 5 degrees out (-10 with the wind chill)! And in case anybody was wondering, if you drop one of the smaller nuts (due to frozen fingers or something) and can't find it, the nut on the field terminal of an old Ford alternator fits perfect.
__________________
1997 F350 XLT: PSD, AT, CC, DRW
1995 Bronco XLT: 5.0L, ZF S5-42
1966 Galaxie 500: under construction!
  #44 (permalink)
Old 03-04-2006, 09:15 AM
vastroker1975 vastroker1975 is offline
vastroker1975 is starting off with a positive reputation.
when changing the glow plugs, I understand that I have to remove the valve covers. Now I priced out gaskets, and they want 136.00 at autozone for these per side. Has anyone came across this, and have you had to change the gaskets? I have a 96 7.3L PSD.
  #45 (permalink)
Old 03-04-2006, 09:27 AM
blue96psd blue96psd is offline
blue96psd is starting off with a positive reputation.
go to international 86 bucks for 2
i paid last week i am replacing mine when i do my GPs and the injectors
__________________
1996 f250 2 tone blue 4x4 frp shim, tymar intake, black cloud diesel stack kit 5in of course and tymar downpipe BCD 3 pillar gauge pod now to add some real power
Tags
1826703c1 , 2003 , 73 , 73psd , 97 , bad , diesel , ford , glow , gpr , hard , meter , ohm , pics , plug , powerstroke , signs , smoke , start , test , white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
