91 F-150 Stalling problems?
Ok so here is the problem I'm having with my '91 F-150 ext cab 4x4. When I start the truck up, It DIES, or when gets to idle it does sometimes, after revving the gas. But then if it does not die at idle, when I but it in reverse or drive it dies. Then if I drive down the road and stop at the stop sign it again dies. The check engine light comes on but then goes off when I drive it a little. Ok so then when the truck warms up it does not do any of this.
KOEO (key on / engine off)
63 - TPS circuit has intermittently failed below minimum 0.6 volts.
fficeffice" /><O></O>
CM (Continues Memory)
31 - PFE or EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
32 - EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
81 - Air management 2 circuit failure (AM2/TAD).
87- Voltage was not detected on Fuel Pump Monitor while the engine was running.
clarkbre
04-28-2014 10:40 PM
BRay09
11-24-2009 07:04 PM
