Ford Exhaust leak! - Ford Truck Enthusiasts Forums
Ford Exhaust leak!
Old 04-25-2002, 02:55 PM
76fordman 76fordman is offline
76fordman is starting off with a positive reputation.
Ford Exhaust leak!
I have a 1976 F-150 Supercab with a 1973 400 motor. The other day it started making a ticking noise, so I got up under the pickup and it has an exhaust leak right where the exhaust pipe goes into the manifold. The bolts are extremely tight. Is there a gasket in there that prevents exhaust from leaking out or do I need to try and tighten it even more. Any help would be appreciated. Braxton
Old 04-25-2002, 03:31 PM
KJKozak2 KJKozak2 is offline
KJKozak2 is gaining momentum as a positive member of FTE.KJKozak2 is gaining momentum as a positive member of FTE.
Ford Exhaust leak!
Sorry I can't answer that yet, but I'm going through this same thing on my 460. I replaced the exhaust manifold gasket and had to put new studs on the manifold. I torqued them to spec and it leaks like a sieve. I even tried to tighten it more to the point of almost bending the flange. No change.
The donut-like metal gasket on mine appears to be part of the manifold so I can't replace it. I plan to work on it tonight until it's fixed, so I can let you know in the morning what I find.
Hopefully some of the more learned folks here will have a solution before then.
Kevin K.
Old 04-25-2002, 05:23 PM
ford_nut ford_nut is offline
ford_nut is starting off with a positive reputation.
Ford Exhaust leak!
hi
there is a donut gasket that is sandwiched between the the manifold and the exhaust pipe. if that gasket blows out, you will get a nasty, annoying leak! if you can remove the 2 nuts off the studs and drop down the exhaust pipe, you should be able to replace that gasket. i believe that they are no more than $2.00 each! the trick however, is GETTING those nuts off! GOOD LUCK
Old 04-25-2002, 11:39 PM
7220driver 7220driver is offline
7220driver is starting off with a positive reputation.
Ford Exhaust leak!
Somtimes the only way to loosen the nuts is to heat them with a torch to break the rust free. also,I've had good luck replacing steel nuts with brass, these will not corrode.
Old 04-26-2002, 12:27 AM
Vampiro Vampiro is offline
Vampiro is starting off with a positive reputation.
Ford Exhaust leak!
if you can't get the bolts out wouldt something like seal a gasket or a liquid gasket that gas or oil and stuff doesn't affect?
Old 04-26-2002, 01:28 AM
Unclej78 Unclej78 is offline
Unclej78 is starting off with a positive reputation.
Ford Exhaust leak!
1990 351W Van Exhaust manifold leak? HardScrabble Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 08-29-2011 11:10 PM
exhaust manifold to pipe Tomm Ranger & B-Series 4 01-28-2010 05:04 PM
Sounds like an exhaust leak masterson32 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 3 12-17-2009 02:45 PM
351w Exhaust Leak - Passenger Manifold JW 4x4 Exhaust Systems 1 10-08-2003 11:28 AM
Hidden Exhaust Leak? Lookinfurfun 1987 - 1996 F150 & Larger F-Series Trucks 8 09-14-2002 12:49 AM
Tags
1976, exhust, ford, leak, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
