10-30-2005, 08:57 PM
You probably are right about it being a broken bolt in there. If it was mine, I'd remove the water pump and try to remove the broken bolt. If you do remove the pump, don't forget about the 'hidden' bolt inside the water inlet, use a six-point socket and turn the bolts to tighten them a tiny bit before you try to remove them. Good luck. ...Terry
__________________
It is a simple task to make things complex,
but a complex task to make them simple.
