Distributor Advice - Ford Truck Enthusiasts Forums
Distributor Advice
Old 10-27-2005, 09:53 PM
klatt_89 klatt_89 is offline
klatt_89 is starting off with a positive reputation.
Distributor Advice
Does anyone have a later model Y-Block Distributor or what is a cheap replacement? Are there any interchangable distributors?
thanks-dklatt
Old 10-28-2005, 09:20 AM
312 312 is offline
312 is starting off with a positive reputation.
i think you can still buy a new replacement dist,for around 60.00.someone on here should know where.
Old 10-28-2005, 10:55 AM
Another question as i got a dist. from Napa for $58 with shipping. How hard is it to take a distributor off a y-block? Any tips or directions would be helpful.
thanks for the help
dklatt_89
Old 10-28-2005, 11:37 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Taking it out is real easy, unless it is stuck, in which case people have used WD 40 or the like on the distributor base, soaking it for several days.
When you put it back in, make sure the number 1 cylinder is TDC on the compression stroke. Insert dizzy with cap off, so that rotor ends up pointing at the number one wire on the cap. Make sure upon insertion of dizzy that it sets down fully, engaging oil pump drive shaft.
Klatt, just curious. Did you get the distributor from NAPA without turning in a core?
Old 10-28-2005, 11:39 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
to remove, disconnect wire from the coil, remove vacuum advance line, remove cap, remove hold down bolt and pull straight up, watch the rotor turn as you remove it and replace the new one in the same location..if it doesn't seat completely against the block don't force it, just turn the engine over a little bit till it drops in..connect coil wire,snug the clamp down bolt and retime it...then reconnect vacuum line
Jim
Old 10-28-2005, 11:46 AM
yea, it's core change on the Napa, but that's when it gets here. Does anyone have a diagram of the wiring of the Y-block?
Thanks for the Help
dklatt_89
Old 10-28-2005, 09:22 PM
46yblock's Avatar
http://www.ford-trucks.com/user_gall...=70062&width=2
This is a link from rogerf100's gallery.
Old 10-29-2005, 09:21 PM
286merc 286merc is offline
286merc is starting off with a positive reputation.
I get my new dizzies from Advance Auto. $55 and no core. They are of the post 1965 replacement design that uses an O ring as in the SBF 289, etc. These are new production, made by Cardone.
Getting a stuck original out can be a problem at times. After several days of PB Blaster on one it still required the help of a slide hammer arrangement I cobbled up.
Tags
block, diagram, distributor, shaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
