76 F250 4x4 ball joints
I figured the ball joints would be a pain to do...I'm not too far in the job and I'm stuck.
Pulled the rotor off, now I have to get the spindle shaft... any advice on getting it off?
My haynes manual just says remove the nuts and carefully remove the spindle shaft...well, the
nuts are off and it ain't moving . I've wd-40'd, pryed, hammered, and cursed for 2 hours,
so I'm thinking I must be missing something.
Get the right size "pickle fork" (KD Mfg brand are the better ones)
and have at it. If you use any heat, just go with the bare minimum to expand the forging but not ruin the temper of the steel. I'm assuming you've got the suspension spring safely accounted for when the BJ seperates. Have fun!
