Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2005, 09:49 AM
nygator nygator is offline
nygator is starting off with a positive reputation.
where to get 10w30 ?
i just moved to a cold climate for the fist time . i have always used 15w40 in all my diesel trucks. [ tampa area ] i now live in southwest new york. i cannot find any 10w30 for my f350 7.3 . can any body tell me where i can find 10w30 ? and why is it so hard to find ? my manual clearly states the use of 10w30 below 32 degrees. thanks for any help.
  #2 (permalink)
Old 10-27-2005, 10:31 AM
JD717 JD717 is offline
JD717 is starting off with a positive reputation.
Most ANY autoparts store carries it. look there.
  #3 (permalink)
Old 10-27-2005, 12:30 PM
lukecline lukecline is offline
lukecline is starting off with a positive reputation.
If you were to switch to synthetic oil you could still run 15-40. synthetic wont get thicker in cold climates like regular oils. Just my .02
luke
__________________
99 cc f250 4x4-wildman tuning, wop twins, di ic, richter trans, casserly fuel
96 cc f250 4x4 -38r turbo, stage 1's, TW tuning, elec fuel system, stage 1 trans, intercooler- formerly 12.52 @ 110 mph
  #4 (permalink)
Old 10-27-2005, 01:17 PM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
Have you tried sponsors of these forums-Redline or Royal Purple?
  #5 (permalink)
Old 10-27-2005, 02:23 PM
utahtom's Avatar
utahtom utahtom is offline
utahtom is gaining momentum as a positive member of FTE. utahtom is gaining momentum as a positive member of FTE.
nygator- Great question. It sometimes can be a real problem finding CI-4 (or CI-4+) diesel rated 10w30 motor oil...Neither Red Line or Royal Purple offer it and I have never seen any CI-4 10w30 at a chain Auto Parts store. Keep in mind that I believe there are only three major brands available: Rotella, Mystik and Motorcraft Super Duty.
The most obvious place is the Ford dealer for the MC- Just be certain it is Super Duty.
Mystik is usually carried at Farm Supply type stores or you could go to their website and check for dealer locations-Do the same for Rotella and/or check at Wally World or local diesel repair shops. All three brands should be readily available, just shop around for best pricing.
Of course, you could always use a 5w40 synthetic which is carried at most Auto Parts stores (& Wally World) in the Rotella and Mobil1 Truck & SUV... Or go to an Oil Distributor (or local Truck Stop) and get Mobil Delvac1 5w40 synthetic. Good luck and let us know how the search goes
__________________
06 Tow Boss F350 DRW/4.30 CC Lariat LB FX4 TS 4X4 6.0PSD
Truth is confrontational: There is no 1 ton Dodge/Cummins or GM/Duramax rated to legally tow what I pull
6.0 Grin Since 2/26/03
Utah Chapter Leader
  #6 (permalink)
Old 10-27-2005, 05:12 PM
utahtom - thanks for the help. all the local tractor stores stock only 15w40. the 2 local ford dealers seemed very confused with my inquiry . i dont think too many people around here have diesel trucks. i know i can order motorcraft oil over the internet. part # xo10w30qsd . i was hoping to find another local source, but i think thats not going to happen. i still cant understand why it is so hard to find. here is a short list of acceptable 10w30 , i just cant find it. cheveron delo 10w30, texaco ursa 10w30, quaker state fci universal 10w30, kendall super d3 10w30, citco mystic jt8 10w30. thanks again.
  #7 (permalink)
Old 10-27-2005, 08:40 PM
f_ford_custom f_ford_custom is offline
f_ford_custom is starting off with a positive reputation.
Just thought I would give ya a heads up. No one certifies cold weights other than 15w (dino & Syn) and 5w (syn only) for diesels. I drive big trucks, and if you could find other weights, they would be in truck stops for sure. 15w40 and 5w40 are all i've seen.
JCWhitney sells magnetic oil warners that stick on your oil pan, I think its a 15-20 minute thing. Just remember to plug in BEFORE you start your truck, and unplug it B4 you leave.
I live in Ga, and we mostly just add Lucas and dont worry about it unless it drops below +10*F. With the 5w40 + Lucas, you should be good down to -5*F, just remember to let the engine warm before revving it over 1000. Also remember that just because the water temp is up to normal doesnt mean the oil temp is above 100. Oil is still concidered 'cold' at 120.
Tags
10w30 , 15w40 , ci4 , delo , jt8 , motor , motorcraft , mystic , oil , qsd , regular , rotella , x0 , x015w40qsd , xo10w30qsd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
