My First Post and ???
Hi I'm new here and to ford so here is my first post. I might be getting ready to buy a 2001 ford F-350 4X4 XLT with a 5.4 V-8 and towing pkg. Is this a good truck for plowing with that small of an engine and I don't think it has a plow prep pkg on it either is that a problem? Thanks!!!
hello gatewayuser welcome to FTE! take a few seconds and look around, read the "read firsts"
yes, that truck will be sufficient for plowing. however if you are interested in modifying your truck for fun, i would look into a diesel. yes a little more costly at the initial thought, but in the long run it pays off. the guys on here will be sure to give you PMS (Powerstroke Mod Syndrome)
Welcome to the site!
I don't really know anything about snow plowing, but, without the plow prep pkg, it's likely that the front will really drop with the weight of a plow. Spring rates are chosen based on chassis configuration and engine options. A truck with a 5.4 gets the lowest rated springs for a given chassis config. It'll probably work OK- just keep an eye on the front end to make sure nothing is over-stressed.
on
1 Post
My boss has about 8 or so Super Dutys that all have the 5.4 engine in them. He uses them for plowing and says he doesn't have any problems. This will be my first year plowing for him (I have plowed for a few years with my dad before this) so I guess I will see how it goes.
As for the snow plowing package I would maybe think about swapping out the springs for the heavy duty ones that come with the plow package. Well worth the upgrade IMHO.
See ya on the boards!
-Matt
on
1 Post
If you have some weight in the back of the truck and there isn't much snow it is VERY possible to plow in 2 wheel drive. Today I was plowing in 2 wheel drive with a stock 2006 F-250 and the box was empty. But it was only 1/2" of wet snow.
gatewayuser: Did you end up replacing the front springs to the heavier ones?
-Matt
-Matt
plow package
I didn't read all the posts but my buddy has a '02 5.4 the he plows with and it does just fine. Another friend just put a 8' western ploy on his '00 f250 V10 super cab (no plow prep) and it does sag bad at all
you have to remember there are guy's out there tryin' to use 6.0L chevys
FYI my boss really liked my 8 1/2 western V-plow that I run on my '01 F350 V10 so he went down to the western dealer w/his '03 Chevy 2500HD and they told him they won't put'em on chevys, they're just too heavy for those little trucks HEHE
