Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-03-2005, 11:21 PM
Bdox's Avatar
Bdox Bdox is online now
Iconoclast
Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation. Bdox has a spectacular reputation.
Hey bigredman, that sounds like a great excuse to buy yourself some really big tires!!! That will slow your engine speed down.
  #17 (permalink)
Old 11-03-2005, 11:39 PM
Jebadiah04 Jebadiah04 is offline
Jebadiah04 has a good reputation on FTE. Jebadiah04 has a good reputation on FTE. Jebadiah04 has a good reputation on FTE.
t-18 vs np435
np435 is stronger, and lower geared, shifts better. But...ive never seen a t-18 come up short from a 435 either. they are both VERY strong, and my t-18 shifts really well in my 86.
they made a 435 and t-18 for a long time.
if you are searching for one, look at the door codes A means NP435 and F means t-18.
a t-18 is what im putting behind my 460, but thats just my oppinion.
  #18 (permalink)
Old 11-04-2005, 12:03 AM
Icicle's Avatar
Icicle Icicle is offline
Icicle has a good reputation on FTE. Icicle has a good reputation on FTE. Icicle has a good reputation on FTE.
Both great transmissions. Both bulletproof...
I dont think youd go wrong with either choice
__________________
WoW Server is down, So Im on FTE......
  #19 (permalink)
Old 11-04-2005, 12:26 AM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE. mustange70 has a good reputation on FTE.
I'd find a t-19, just as strong, few more gearing options, as well it fully synocro'd
__________________
Cody, Calgary
AB Chapter Leader
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #20 (permalink)
Old 11-06-2005, 01:04 PM
oldhalftons's Avatar
oldhalftons oldhalftons is offline
oldhalftons has a good reputation on FTE. oldhalftons has a good reputation on FTE. oldhalftons has a good reputation on FTE.
in theory, on paper, the t-18 and t-19 are stronger. They were used in light and medium duty trucks. the NP435 was only OEM in light duty trucks.
The NP435 has a slightly lower creeper (6.69:1 vs 6.32:1) so its a better crawling transmission. the T-18 is easier to speed shift 3rd to 4th.
the T18-B is a good 4spd for a grocery getter truck because it doesn't have a creeper, but its 4.32:1 1st gear is still unsycronized
  #21 (permalink)
Old 12-19-2005, 12:04 PM
bloodhound51 bloodhound51 is offline
bloodhound51 is starting off with a positive reputation.
i have a an np435 in my 75 250 it has never failed me you will loose traction before you will bog the truck in 1st gear
  #22 (permalink)
Old 12-22-2005, 02:27 PM
turbocoupe5.0 turbocoupe5.0 is offline
turbocoupe5.0 is starting off with a positive reputation.
I had a T-19 in my 87 before I swapped in a ZF 5 speed. 1st is still a granny gear, it's just not as low as the NP435 or T-18 and I believe it was syncro as mentioned above. Otherwise, I believe it is about identical to the T-18. I still have it along with the bell housing, etc for a 460 4x4. It needs a rebuild though. One of the reasons I swapped in the ZF was because it had wicked bearing noise. It wined like it had strait cut gears and rumbled when idling in neutral. I drove it like that for 2 years though and it still shifted fine and never jumped out of gear.
__________________
87 F250, 4X4, 460 (cam, headers, Perf. int.), 4V, ZF 5spd, 4.10's, 8600GVW, reg. cab, 8' bed
88 T-bird T-coupe, 302 swap, GT40P heads, cam, GT40 int., Megasquirt EFI, headers, 5spd, 3.55's, no turbos yet!
  #23 (permalink)
Old 12-23-2005, 07:47 PM
fordfan302's Avatar
fordfan302 fordfan302 is offline
fordfan302 is starting off with a positive reputation.
Is it normal for the t-18 to whine??? Because I hear really bad in 1st, 2nd. and 3rd on my truck
  #24 (permalink)
Old 12-23-2005, 08:38 PM
Quote:
yes and no (don't you like those answers? )
the 4 speeds with any spur gears at all are louder than transmissions with all helical gears, so you will hear them. old T98's and T18's with Reverse up and right can be pretty loud. At what point normal gear noise becomes a symptom of a problem is hard to say without hearing it.
  #25 (permalink)
Old 12-26-2005, 07:09 PM
lisagoud lisagoud is offline
lisagoud is starting off with a positive reputation.
Just to let you know both NP435 and T-18's were used in Fseries trucks all the way up to 1989 (at least)...I have 2 1986 F250's one with NP435 and one with T-18. Other than the fact that you can't swap parts between them. I can't tell any difference. Jeep owners I'm told seem to try to get T-18's for change outs but I don't know why they couldn't also use NP435's?
  #26 (permalink)
Old 12-26-2005, 07:57 PM
Bdox's Avatar
Iconoclast
What vehicles came with the T-19 trans.?
__________________
Bruce, Nevada Chapter (gone power mad!)
A worthy goal is to try to be counted among the ethically and intellectually valuable people.
Did you get that air guitar that I sent you?
  #27 (permalink)
Old 12-26-2005, 10:08 PM
brokebronco's Avatar
brokebronco brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.
Either choice is a good one. What it boils down to is which one you come across first. Just make sure the bearings and seals are good, fill it with the proper oil and run it like you stole it.
Chris
__________________
Chris
84 Bronco 351HO/NP435/208/10.25 Rear/D60 Front
86 F250 351HO/C6/10.25
New rig
96 F350 crewcab 2x4 with the 7.3l
  #28 (permalink)
Old 12-27-2005, 12:21 AM
Quote:
late 80s (definatly in 87, I have one) F250's over 8600lbs and F350's
  #29 (permalink)
Old 12-27-2005, 08:12 PM
dlbelton's Avatar
dlbelton dlbelton is offline
dlbelton is starting off with a positive reputation.
Quote:
Because Jeeps also came with the T-18's, but with different input shafts. The Ford T-18's are much easier to find and parts are cheaper, so ones looking to do conversions look for the Ford T-18's and use the Jeep bellhousings. Everything bolts right up, but they have to use a Ford clutch disk/pressure plate
  #30 (permalink)
Old 12-27-2005, 10:08 PM
Thomasm67's Avatar
Thomasm67 Thomasm67 is online now
Thomasm67 is gaining momentum as a positive member of FTE.
Look at the top cover a 435 will have aluminum top cover and a T18 is all cast iron that's how you can tell what you have.
__________________
Only the Best and Finest Drive Ford Trucks in the
Kansas Chapter
76 F250 Hiboy/390/35's/4.10's
92 Explorer/3.73's/4.0/235's
Tags
1st , c6 , codes , ford , gear , id , jeep , loud , noise , noisy , np435 , strong , t18 , transmission , whine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
