truck creaks when lurching forward (usually only when cold)
The frames on these truck tend to twist a little on uneven terrain. Nothing really to worry about. It is better to have a little twisting action than to have a really rigid frame.
The cab on my truck even flexes a little on uneven terrain. You can hear the door move in the opening as you flex the frame.
Might be shocks/suspension creaking.
Come to think, my 86 F-150 creaks a bit when cold. Mainly when the temps get down below 20 degrees. Creaks disappear after driving for a while unless it is really cold.
Heck, really makes some noise when water has managed to freezed in the suspension on snowy/wet/cold days.
There was a post awhile back on creeks and pops of the frame. The post showed the tranny crossmember is relieving stress. On a flat surface loosen the tranny mount bolts, then loosen ALL the crossmember bolts, (top and bottom rail channels). tighten all the crossmember bolts, THEN the tranny mounts. ........Mine stopped "creeking"
Reamer
'86 stepside 4x4
Reamer
'86 stepside 4x4
My truck would always do this after it rained. I narrowed it down to the Leaf spring bolts. So I ended up removing and lubing the leaf spring bolts. This took care of it. Now I have to change the rr sway bar end link bushing as they are rubbing on the frame and making a new creeking sound. I got the Energy Suspension bushing for this job. Country
robert196614
01-30-2014 03:57 PM
smartass_kid
04-08-2011 06:43 AM
mroberts
17
10-18-2006 02:28 PM
