The driver side Power Window on my 2001 f150 go's down with no problem, but when go's up it is real slow and today will not go up at all. Any suggestion on the cause?
try lubeing the black felt window runs that the window goes up and down in with some silicon spray.if that dosnt work you probably have a weak window lift motor.
