Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #421 (permalink)
Old 09-07-2008, 11:18 PM
havi's Avatar
havi havi is online now
Collector of rust
havi is gaining momentum as a positive member of FTE. havi is gaining momentum as a positive member of FTE.
It was fairly dark outside still, and I couldn't get up close to the firewall. My flashlight caught the HF on the upper right corner of the serial plate, and that was about it.
__________________
I lack focus. That, and I lack focus.
1948 F1
1950 F6
1978 F150 4x4
several others for parts
Also looking for a 1937 Ford sedan 2dr, and any old panel truck.
  #422 (permalink)
Old 09-08-2008, 12:13 PM
texan2004's Avatar
texan2004 texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
Any chance that Paint Code was a plant code and said HP? OR given your location, SP for Saint Paul?
__________________
2003 F-250SD, 6.0 PSD
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #423 (permalink)
Old 09-08-2008, 07:58 PM
havi's Avatar
Collector of rust
This truck is up on the Canadian border west of International Falls, MN. Doesn't make much sense to me either. Whenever I get it home, I'll get a better look, though.
__________________
1948 F1
1950 F6
1978 F150 4x4
  #424 (permalink)
Old 09-09-2008, 08:29 PM
four8fordf1 four8fordf1 is offline
four8fordf1 is starting off with a positive reputation.
Quote:
Originally Posted by four8fordf1 View Post
1 - 1949
2 - VIN # 97HC * 210165 * SP
3 - Bed - Raised Panel
4 - Is this the original bed, Yes
5 - Transmission (Four Speed)
6 - Floor shift
7 - # SP 2E 400346
? SP=St. Paul, this truck came out of North Dakota so that makes sense.
? HC=Six Cyl. Is this correct
? 97=What What does the 97 stand for
? 2H=2nd of May From this post, truck must have been assembled May 2nd
? 400346 On the fire wall, what do these number decode to
I just got back from South Dakota and my uncle confirms that my truck was purchased at a farm auction in North Dakota in 1987 from the original owner. It was blue when he got it. He had it painted red at a later date. I am interested in returning it to it's original color. The number stamped on the fire wall has been confirmed as correct "SP 2E 400346" What color blue was it originally
Regards,
Jerry Johnson
  #425 (permalink)
Old 09-10-2008, 12:15 AM
texan2004's Avatar
The paint code seems to be missing from the firewall stamping. If it was blue, I believe the color was Sheridan Blue and the paint code for that was either "B" or the number "5"
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #426 (permalink)
Old 09-16-2008, 09:25 AM
nanny3 nanny3 is offline
nanny3 is starting off with a positive reputation.
Have 59 F100 made in Canada Have noticed trucks made in US and Canada have differ ways for their Vin systems mine is 6991018YK-58608 can anyone help me
  #427 (permalink)
Old 10-18-2008, 10:41 PM
R A Wrench R A Wrench is offline
R A Wrench is starting off with a positive reputation.
Howdy; I am in the proccess of reviving an F1 that I bought out of state. It was titled as a 49, F2 but I have some doubts. The truck has been street rodded and many things have been altered, some parts were missing. Here is some of the info I have come up with.
87?C96878 the ? may be an R. Faintly stamped in rt ft frame rail
10LB21E09 stamped in driver side firewall
firewall tag only has LB stamped at far right
No glove box door= no VIN tag
Original color is light gray, raised box sides, stainless grill trim, hole in trans cover= floor shift, small back window, holes for both sun visors & wipers, fresh air intake over right headlight & heater hole in right kick panel area. I think that someone may have cleaned out the storage shed and put some of this together, way back when.
This site is great, way more info in one place than I could hope to dig up, Thanks. Rick
  #428 (permalink)
Old 10-18-2008, 11:05 PM
havi's Avatar
Collector of rust
8=1948 7H=6 cyl. flattie C=F1, the remainder should be the production sequence. Someone may correct me if I'm wrong. Oh, and welcome to the board!
__________________
1948 F1
1950 F6
1978 F150 4x4
  #429 (permalink)
Old 10-20-2008, 11:20 PM
texan2004's Avatar
Havi has it right:
8 = 1948
7H = Flathead 6
C = F1 - 1/2 ton
96878 is the seuence h\number and it is correct for a 1948
The firewall stamping is as follows:
10 = Color code = Unknoiw. I've seen this color code one other time. I also have 4 and 11 as possibilities for grey.
LB = Long Beach, CA assembly plant
21E = May 21 build date. Assuming that the cab came with the frame, it would be 5/21/48 but not all plants were doing firewall stampings in 1948, Some did but it did not become commanplace until the 1949 model year. I do not have any other examples of 1948's from Long Beach with firewall stampings,
The SS grill trim could mean the body is a 48 if it is the original grill r someone vould have aded it later. There are some other small difference between 48's, 49's and 50's but they are minor and could have been added as replacements for a broken part at some point in the trucks life.
Enjoy the truck and thank you for the information.
Carl
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #430 (permalink)
Old 10-20-2008, 11:23 PM
texan2004's Avatar
Does the vin # on the title match the one on the frame rail? Is the trcuk and F1 or an F2? The F1 has the 6' bed and the F2 has an 8' bed, 8 lug wheels. etc.
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #431 (permalink)
Old 10-20-2008, 11:29 PM
havi's Avatar
Collector of rust
Carl, the earlier factories "no stamp" seems to be true. I found my low prod. # serial number truck's date stenciled inside the cab below the rear window. I can't remember the date off hand. But as mentioned in my previous post, I couldn't find any stamping on the firewall....now I know why, lol. post #'s 416 and 417.
__________________
1948 F1
1950 F6
1978 F150 4x4
  #432 (permalink)
Old 10-20-2008, 11:39 PM
texan2004's Avatar
I know that some of the 48's had dates stenciled on them in various places. Yours may be one that I am thinking about. This stuff woujld make an ISO auditor's head explode in today's world
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
  #433 (permalink)
Old 10-22-2008, 05:58 PM
thanks for the info on the F1. In reply to Texan #430 post, the title # and the VIN # on the frame do match. It is a 1/2 ton, short box, don't think the frame has been cut and having been street rodded, it is running regular Ford wheels, not light truck. Don't know why the previous title had it as a 1949 F2 but mine just states it is a pickup. No Problem.
  #434 (permalink)
Old 11-20-2008, 10:21 AM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 is starting off with a positive reputation.
here's a new one for ya . the fella , now freind who bought my old f-4 just latched onto an f-6 at a farm auction . got a six for power and here's the vin which i havent been able to get the decode to tell me anything other than it's another 49 ;98 mth 7031 C . he's gonna look and see if that was right . also told him george , to wander on over here and sign up and introduce himself . here's a pic he sent me of my old f-4 and the newly acquired f-6 he has .Name:  fordf6truck2008_012.jpg
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #435 (permalink)
Old 11-20-2008, 01:14 PM
texan2004's Avatar
Quote:
Originally Posted by 55 f350 View Post
here's a new one for ya . the fella , now freind who bought my old f-4 just latched onto an f-6 at a farm auction . got a six for power and here's the vin which i havent been able to get the decode to tell me anything other than it's another 49 ;98 mth 7031 C . he's gonna look and see if that was right . also told him george , to wander on over here and sign up and introduce himself . here's a pic he sent me of my old f-4 and the newly acquired f-6 he has .Attachment 12064
98MTH7031C
9 = 1949/50
M = 254 cid. Flathead 6-cyl (110HP) - This engine was only offered in 1950 so you have a 50, not a 49.
8TH = 2 Ton (158" Wheelbase)
7031C = VIN Sequence #. Can you have him double check the C? Is it a 0 or a 6? There should not be a letter there. Also, can you have him check the firewall for a series of numbers stamped into the firewall (not a data plate)?
Thanks
__________________
2008 Lincoln MKX
1996 Explorer Sport
1950 F1 (4 ea.)
1949 F2
1948 F6
1950 F6
Tags
1949 , 1950 , 1950s , 49 , code , decode , decoder , ford , number , older , restoration , restorations , truck , trucks , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
